11-12-2014, 03:42 PM | #1 |
Rear wheel well liners
Has anybody fitted any kind of wheel well liners to the rear?
I was thinking of getting some of the ABS ones for a F150 anf trimming them to fit since they look about the right shape. The Chevy ones are flat across the top. http://www.summitracing.com/parts/rlr-wwf15004 This is to protect the underside for the fenders from road debris. |
11-12-2014, 04:28 PM | #2 |
Re: Rear wheel well liners
Have not thought about those kind of liners. To protect mine I'm using 3M Paint Defender. Two years and about 12K miles, no rock chips, dings, etc. Easily wipes down clean. I did both front and rear wells and the area below the lower moldings.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-12-2014, 11:29 PM | #3 |
I used heavy rubber from a floor mat combined with vinyl push pin molding mounts to fab up liners. Works pretty good. On my Dodge I bought liners that did not fit right a heat gun helped reform them
71 C-20 Custom Camper California Truck |
11-12-2014, 11:47 PM | #4 |
Yeah I was thinking about fabbing something up out of mudflap material or something similar. How did the push pins work? Did you drill into the fender at all?
11-13-2014, 11:27 AM | #5 | |
I looked into the same thing you referenced at the top but was afraid of fitment issues. For the front wheel wells we did tap small holes into the bottom lip of the fenders. That material has stayed perfect and really cut down on splashing of dirt and mud onto the underside of the truck.
11-13-2014, 01:12 PM | #6 |
I have an F150 with the factory installed fender liners. I compared them visually to my 1970 fleetside fenders and they are not even close to the right shape. I don't think any amount of trimming could make them work.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
11-13-2014, 02:20 PM | #7 |
Good info, thanks Kennuck.
I guess it's fabrication time! |
11-13-2014, 02:39 PM | #8 |
I was thinking about just spraying on an undercoating on mine has anyone tried this?
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
11-13-2014, 03:36 PM | #9 | |
My search for liners was because of the large gap in the front where there is a lot of fender exposed. |
