Old 11-12-2014, 05:06 PM   #1
Guilty-by-Design
Guilty-by-Design's Avatar
Steering column help
Having some trouble with my steering column explained in the video that sometimes I can't start my truck unless I push in on the steering wheel also I'm trying to figure out why we reverse lights also aren't working. both problems started after replacing turn signal switch
http://s109.photobucket.com/user/gui...04422.mp4.html
Guilty-by-Design is offline   Reply With Quote
Old 11-12-2014, 06:02 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Steering column help
make sure you have the wiring properly connected
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-12-2014, 06:17 PM   #3
Guilty-by-Design
It should be connected right, there was only one flat connector to reattach and the turn signals and hazard lights work fine just not the reverse lights.
Old 11-12-2014, 06:45 PM   #4
Just call me Sean
Just call me Sean's Avatar
Reverse lights are a different switch, which you probably knocked loose. Same switch for the neutral safety.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 11-12-2014, 07:28 PM   #5
bnoon
^^^ This! I had this issue after I swapped columns and didn't have this connected properly. The connector is very easy to pull off and wriggling all the other harnesses around there did it to me...
For your other issue, the push the steering wheel thing, there's not much you can do to that replacing a turn signal switch itself unless you reassembled the steering wheel parts incorrectly. The ignition switch moves the steering lock post out of the way of the lock collar and that's it. Pull the steering wheel and see if it works any better without the wheel on. If it's still sticky, look at the turn signal piece to make sure it's not dragging on the lock collar.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 11-12-2014, 07:31 PM   #6
bnoon
Found a picture of the lock collar and pin... Nothing in the way as long as you put that collar back on right.
Old 11-12-2014, 08:03 PM   #7
Guilty-by-Design
Ok will look into it some more, and pull the wheel again to double check I reinstalled everything properly.
Old 11-13-2014, 11:42 PM   #8
Guilty-by-Design
Somehow when I installed these screws I didnt have them torked down giving the wheel enough play that it wouldent start, so with a healthy helping of locktite I made sure they were good and snug. Thats one problem down but I still dont have reverse lights and I have checked the other two connectors at thebase of the steering column and they are securely in place and all the fuses seem fine... any ideas
Old 11-14-2014, 07:55 PM   #9
bnoon
Alignment on the shifter perhaps??? Have someone stand behind the truck when you go from park all the way through to L1 and back. See if the reverse lights flicker on/off at all.
If that doesn't work, you can send power down the feed to the reverse lights, which I believe is light green??? Can't remember...
Old 03-23-2015, 12:04 AM   #10
Guilty-by-Design
UPDATE: with the nice weather we have been having here in Kansas I had time to fiddle with the truck. I pulled the switch at the base of the column and found it was good so i pulled the bulbs both looked good... LOOKED. after testing the bulbs the driver side was bad and the socket on the passenger side was also bad. this is wast happens when you assume instead of testing.
As for the horn there is little aluminum post that i pushed in and turned which locks it into place however while in the locked position it cannot complete the circuit to sound the horn
just wanted to give this post closure
