Drive it like U stole it
grill ??
I went down today to my friends place and got a outer grill shell for my 71 . My ? is the grill is very dull after I washed it and got all the mold off it ,What can I use to bring the shine back out. I bought some Mothers polish but it not working as good as I thought it would . Any suggestions ?
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
![]() Join Date: Jul 2003
The anodizing has begun to corrode off the grille, which is a real pain to make it look good again.
I have seen some people polish the anodizing layer off, then clear coat the aluminum to prevent tarnishing and corrosion. The only way to truly get it to look like new is to have it sent out and reanodized, but it is more cost effective to get a new grille shell. ![]() |
I saw one last night at the local cruise in and I asked the guy how he did it and he told me mothers so I went and bought some and it hasnt turned out like his yet . I have no money in this shell so that is the reason I was asking . Is there any thing else that will remove the anodizing other than hand rubbing ? I know its most likely cheaper to find another but I would atleast like to try since its in good shape and free.
I took some brasso, a broken drillbit, a screw gun or a fast revving drill and polished it off. Drop some brasso on the shell and wrap the cloth around the bit. Make sure it is thick tho, it could scratch your shell if not. Mine was turning the milky white color and this brought back the shine. Good luck
its all about the +6 inches
spray it with some oven cleaner, let it sit for 5 or tem min, and rince it off. That shouyld remove a little of the anodizing. Do it over and over untill it is all gone. You want to do it in small quick steps so the actual alluminum does not get damaged by the clenaer.
Once you have it all off, you may want to wet sand the grill with 100 grit, and maybe even 2000 grit wet sand paper, and then use the mothers ( I like there wheel polish...real good stuff) and if you have a dremel or simalar tool, use it. You'll have quite a bit of time in it, but if you keep at it, it can look almost like chrome. This will be a high maintnance item once you hace done it. A quick but good polish every week or two should keep it's shine. |
67-72 Addict!
I had a friend of mine do my Dads' 70 grille for me and turned out awesome. His name is Mark and he is a polishing maniac!. Tell him Jim sent ya! http://www.ieasysite.com/starquestrims/
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
