Carpet hold down strips?
Are the front and rear carpet hold down strips the same or are they different? The two I have out of my 72 K5 are the same but it had a vinyl floor mat and I am replacing with carpet. I saw where someone had two for sale in the for sale section and they appeared to look different! Thanks, help appreciated.
GMCDAC
Re: Carpet hold down strips?
The ones out of my '70 GMC Jimmy are the same but I got a pair several years ago from a '71 or '72 Jimmy that had two different ones. I don't know the flooring that was in the latter but my '70 was stock with carpet and has the CST option.
DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! ![]() |
I'm trying....
![]() Join Date: Oct 2013
More knowledgeable voices please chime in, but what I've surmised from hunting these things is:
1. There are obviously two types (clamping ribbed type, flat with slight bend[pictured at bottom courtesy of BigDon]) 2. I have seen them in all configurations with respect to front and back strip combinations (flat/flat, clamp/flat, clamp/clamp). 3. The flat/flat iteration seems to be the earlier versions and the clamp/clamp the predominant later combo 4. I am often completely wrong, especially when I think I'm sure 5. If you find two good ones...hang onto them.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
I'm the one with the two for sale in the classifieds. From my research, the one that is shown above is the FRONT hold down strip and the one that has a half-cylinder ridge down both sides is the rear hold down strip. Also, I've seen pics of them installed reverse of this, as shown above, with the "smooth" strip at the rear and the "raised" strip at the front.
The ones for sale are from my 1972 Blazer, BTW.
72 K5 Blazer - BCHWGN |
#5 | |
GMCDAC
DAC
#6 | |
I'm trying....
#7 | |
GMCDAC
DAC
I have seen the same as above, flat/flat in 70 and rib/rib and rib/flat in 71-72. The rib does hold the seal for gate. Getting that seal in properly is harder then putting a wet noodle up a tigers a$$!!!
