11-13-2014, 12:58 AM | #1 |
Turn signal lights
Been looking at my options for signal lights wondering about the signal in the grill vs. the signal in the headlight. Thinking the signal light in the headlight would look very cool, but is it bright enough? I know there's a couple options in the headlight. Autoloc sells one called Snake eye and classic parts sells a 10 LED signal in the headlight. Has anyone used these and can people see them at night? I know the halogen light is pretty bright.
Thanks |
11-13-2014, 10:29 AM | #2 | |
Re: Turn signal lights
just googling, I found these, which are very similar if not the exact same from a different manufacturer. http://classicgarage.com/3cham7rounhe.html remember, there is a high low, a turn (they call it a drl, but its big enough for a small turn signal bulb to go in there) AND an h3 fog light in these. lots of light.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
11-13-2014, 06:36 PM | #3 |
Not a big fan of anything Auto Loc sells as guys haven't had great luck with some of their stuff in the past.
The first time around on mine I pulled the single element pigtails out of the stock sockets and installed double element pigtails and used a turn signal bulb that had straight across pins making it interesting when you tried to line the contacts of the bulb up with the contacts of the pigtail. When I redid the truck a few years ago I cut out the stock sockets and used universal sockets that took 1157 bulbs but the clearance behind the lights doesn't leave a lot of room for the sockets to stick out. That worked out well but I did have to find some sockets that didn't stick out that far to the rear of the light housing.
