Old 11-13-2014, 05:55 AM   #1
Andy4639
Old member
Andy4639's Avatar
Question Electric Door locks
I'm wanting to add electric door looks to my truck with remotes. Can someone who has done this tell me what to look for in the Actuators.
What size should I go with and what are some tips for installing them. Pictures are always nice to.
I have found a few kits on E bay but would like to hear what you have to say about them installed in our model trucks before I buy.
Any problems installing them and such.
http://www.ebay.com/itm/1970-1994-JI...ht_2420wt_1124
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-13-2014, 09:56 AM   #2
68shortwide
68shortwide's Avatar
Re: Electric Door locks
Subd.wanna do power locks,windows, and possibly remote start on mine.....
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 11-13-2014, 10:34 AM   #3
praisegeetarman
Make sure you get the high torque actuators. The lock mechanisms on the 67-72's work very hard and need a hard pull.
Keith
praisegeetarman is offline   Reply With Quote
Old 11-13-2014, 12:16 PM   #4
TazmanB
TazmanB's Avatar
Andy check out VH Coachworks I got mine from them and they work great.
http://67-72chevytrucks.com/vboard/s...d.php?t=537720
Or check out A1 Electric. You would have to do some fab work to install the A1 Electric locks but shouldn't be too hard. They also offer a power window kit made for the 67-72 C10's
http://www.a1electric.com/catalog/cat_key.htm
If you ask the question. Make sure you are ready for the answer.
69 C-10 Longbed (In Progress) Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=568171
TazmanB is offline   Reply With Quote
Old 11-13-2014, 12:42 PM   #5
Sammy
Shaved the ones on my GMC. I recommend the largest LB solenoid you can find. I believe mine were 25 lb Autoloc's I used. Plenty of pull for our doors. When you mount them to pull they need to be straight pulling not at a angle inside the door using the cable with a non slipping keeper on the cable. Plan of course relays for full amount of the 12 volts which can lay in the bottom of the doors. Very hard to show pics of setting up the solenoids because it is inside the door. Plus mine are covered with door panels now also. Pull your inside door panels plan well and drill once. I drilled a small hole on each of the stock latches on the doors and that worked well for the cables. Sorta self explanatory when you understand the basics of our stock door latches and places to run power. Then plan your switch locations. Not that hard as it seems to explain. Hardest part is finding power sources and hiding wires. Good luck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-13-2014, 12:59 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
I'd be wary of VH coachworks. They haven't logged onto the forum since March and they haven't updated their FB page in a year and half. It was a father/son team, and the dad had some health issues.
http://67-72chevytrucks.com/vboard/s...=613436&page=2
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-13-2014, 02:45 PM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Electric Door locks
Any one else? I will check A-1 out and see. This is going to be my Christmas gift if I can find one and get my daughter are wife to buy it.
Old 11-13-2014, 03:15 PM   #8
TazmanB
TazmanB's Avatar
I was not aware of the problems that were going on with him and his dad. I bought my items about a year and a half ago. Sorry to hear about his dad and the other issues everyone is having. His stuff was nice quality stuff.
Old 11-13-2014, 03:54 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: Electric Door locks
Just tried PMing them. Got the full PM message. Oh well looked like a great kit. I guess I will try and find another. and maybe add the plate like theirs.
Old 11-13-2014, 04:24 PM   #10
Eddie H.
Eddie H.'s Avatar
I installed a set that my son bought from the LMC truck parts catalog. They work fine with no issues.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 11-13-2014, 07:58 PM   #11
Andy4639
Old member
Andy4639's Avatar
Cool Re: Electric Door locks
Ok thanks. I'll check them out also.
Old 11-13-2014, 11:21 PM   #12
Andy4639
Old member
Andy4639's Avatar
Question Re: Electric Door locks
LMC kit with remotes.
