best lowring springs to go with?
I have a 67 short step side and I was wanting to do a 4/6 drop on this c10 but I was wondering who makes the best spring. I daily drive this truck, autocross it, and drag race it. would ECE,CPP or moroso trick springs be better?
I am a Referee of life.
Re: best lowring springs to go with?
If you're lowering it that much, you will need to use spindles. If you try to drop 4 in in the front with springs only, you will never get good alignment. Any of the major companies you mentioned would work but look into a kit with drop spindles, disc brakes and do it right.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Jun 2014
I would like to know too. I have ECE on the front of my 67 and they ride great. I am now working on the rear.
ECE rear springs are $114 and Hotchkis are $213. Are Hotchkis springs really that much better? |
http://www.hotchkis.net/6772_c10_spo...l_springs.html
I installed this kit on my truck and it drives fine.
-Jason USN Retired |
![]() Join Date: Nov 2001
ECE... always
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
