Old 11-13-2014, 08:11 PM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up Heated/elctric seats
I got the driver's side covered with new heaters installed. I mounted the switch in the factory location. It's all wired just have to get the old seat out and run a switched hot and ground to hook them to. Going to run the ground wire to the seat belt buckle so if you forget to turn it off and unbuckle your belt it will turn off also. This will keep from burning the elements up. No need to have it on if no one is sitting in the seat.
I will have to get them in and out in the sun and run the heaters a few times to get the material to lay down better but over all they look fine I think.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-13-2014, 09:55 PM   #2
tsetsaf
Re: Heated/elctric seats
Looks great. Love the heated seat elements!
71 C-20 Custom Camper
California Truck
tsetsaf is offline   Reply With Quote
Old 11-13-2014, 10:05 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Heated/elctric seats
Thanks, my 08 Tahoe and wifes 2011 Treverse have spoiled me.
Passenger side all done. Going to tested them in the morning and make sure all is well before installing them.
Not bad at all I think for the first time ever doing seats.
Old 11-14-2014, 10:52 AM   #4
Custom 68
Custom 68's Avatar
looking good Andy, where did you end up getting your heaters and covers from?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-14-2014, 03:39 PM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Heated/elctric seats
Hey Dave,
got the seat covers here.
http://www.autoanything.com/seat-cov...A4353A0A0.aspx
Got the heaters off E bay from a guy in Texas. 5 year warrinty with them.
