Old 11-13-2014, 10:28 PM   #1
Gregski
Post Whore
Gregski's Avatar
Adjusting Idle Mixture Screws Does Nothin - Quadrajet
after rebuilding my Rochester Quadrajet 4MV I wanted to adjust the idle mixture screws, YouTube says to adjust by RPM or vacuum, well nothing happens when I screw the screws in or out, no change in RPM speed
what could it be?
it could be a poorly adjusted choke
it could be a vacuum leak
anything in particular I should check and how
1974 GMC 1/2 ton manual 350 V8 all stock
Gregski is offline   Reply With Quote
Old 11-13-2014, 10:52 PM   #2
bnoon
Re: Adjusting Idle Mixture Screws Does Nothin - Quadrajet
If it's idling too fast you can't set idle mixture. Set it when the engine is warm and at low idle in the 600-750 range. You should be able to see the vacuum gauge change position as you adjust.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 11-14-2014, 11:20 PM   #3
Corts60
Just here to tinker
Corts60's Avatar
If they are not responding, you more than likely have a vacuum leak. Check that all gaskets are sealing properly by running the engine and spraying carb cleaner around the base. If the engine speeds up, you have a vacuum leak.
Old 11-14-2014, 11:22 PM   #4
Dead Parrot
The motor needs to be fully warmed up before adjusting the idle mixture. Choke fully open. Idle between 600-700 rpm. Vacuum should read between 18-22 if things are close depending on if your distributor vacuum advance is on ported or manifold vacuum. Timing with no vacuum advance should be around 8-10 BTC to start with.
If vacuum is way low at idle, suspect a leak or poor timing.
Before starting, screw the mixture screws full in until they gently seat. Too hard and you can enlarge the hole in the carb. Note how many turns each is out. Then back them out 1 turn and start adjusting. One turn out should be too lean but this way, you only have one way to adjust. At some point around 1 and 1/2 to 2 turns out, the motor should speed up a bit. Further turning out won't yield more speed. Find the best idle and vacuum reading, then turn that screw in 1/4 of a turn. The motor will slow a bit. Repeat for the other side.
Dead Parrot is offline   Reply With Quote
Old 11-15-2014, 02:57 AM   #5
Gregski
Post Whore
Gregski's Avatar
Thank you all for your advice, I drove the truck in to work today for the first time, and after I drove it back home (10 miles) it was finally warm enough to where after screwing each side in one at a time the truck finally responded and the motor died
Then I turned each screw 2 full turns out from bottoming out and learned that its around 2 full turns that the RPMs are at their highest turning the screw out any further yields no better results, as you also suggested
I tried turning the screws in a bit after that to find that sweet spot but I think the best results were at 2 full turns out
so thank you all for your help, I consider this job done
Old 11-15-2014, 07:56 PM   #6
Corts60
Just here to tinker
Corts60's Avatar
The best way to set idle/mixture is by a vacuum reading. You adjust them one at a time until you achieve highest vacuum reading. Attach the gauge to any manifold vacuum source.
