Old 11-14-2014, 02:23 AM   #1
BCOWANWHEELS
steering box lube question
guys I,am a old crippled fella and I,am almost 100% sure my (c-10) manuel steering box needs lubed. can one of you fellas tell me where the fill plug is located ? its real hard for me to get up and down nowdays. (getting old is a bugger fellas so enjoy your health while you have it)
regards
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-14-2014, 08:01 AM   #2
Bigdav160
Bigdav160's Avatar
Re: steering box lube question
I had to rebuild the manual box in my Corvette after a bearing went bad. I remember using grease in it.
No fill plug for liquid lubricant
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-14-2014, 08:29 AM   #3
yuccales
yuccales's Avatar
I think one of the three bolts on the top of the box can be pulled out to add lube. Someone else will chime in. As for getting older, if you find a way to slow it down, let me know!
yuccales is offline   Reply With Quote
Old 11-14-2014, 11:45 AM   #4
Lou Boffa
Lou Boffa's Avatar
subscribed. As for old, I heard this advice:
Never pass up an opportunity to pee
Never trust a fart
Never ignore an......you get the idea....
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 11-14-2014, 12:05 PM   #5
chewychevy67
you can remove the bolt at the top of the 1st picture (the one that is not in line with the other 3) to add lube to the gear. I also used chassis lube rather than oil to lube mine up.
chewychevy67 is offline   Reply With Quote
Old 11-15-2014, 01:38 AM   #6
BCOWANWHEELS
thanks pal. will get it done.
bob
Old 11-20-2014, 09:08 PM   #7
BCOWANWHEELS
WELL I wanted to experiment some today so i bought a large tube of lubriplate #105 engine assembly white grease . i pulled the bolt out of the steering box,inserted the tube nozzle and put as much as would go in ( about 1/3 of the large tube), put the bolt back in and went for a drive. boy did it ever make a difference. so tomarrow i,am gonna remove the bolt again and see if i can get the box to take more grease. more to come...
bob
Old 11-21-2014, 10:18 AM   #8
Davidf
On the older trucks that actually have a fill plug on the steering box, many people use John Deere Cornhead grease. This grease is self leveling and will really flow well in the gear box. Bob, be careful about packing the box too full as you will want room for the grease to expand when it gets hot. Otherwise, it will have no place to go other than past the seals.
Most manual steering gear boxes don't use straight chassis grease, but rather a self leveling grease. However, chassis grease is a common substitute and I have not heard of rapid wear/failure due to chassis grease. Just FWIW and most of my experience is with 20 year older hardware.
Davidf is offline   Reply With Quote
Old 11-21-2014, 10:21 PM   #9
R.L.
R.L.'s Avatar
This is interesting, thanks for posting.
R.L. is offline   Reply With Quote
