![]() Join Date: Apr 2009
Info Patch Panels
Who Makes The Best Fender Lower Patch Panel, And Door Outter Skin Thanks
1963 Impala 2021 Harley Road Glide 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2006 Silverado 1500 Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
Re: Info Patch Panels
I got all my sheet metal from top banana parts. I did full door skins and the inside lower pieces, driver side cab mounts and floor, inner and outer rockers on both sides (driver is done now).
The door skins fit great, the rest needed "slight modification" which is common with most aftermarket sheetmetal. ![]()
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
| Bookmarks |
