Brake Booster
I'm looking for a brake booster that will work on a 62 C10 with 4 wheel drums and factory pedal assembly. Any help would be great..
Thanks Brandon |
Re: Brake Booster
Lots of good info here. http://67-72chevytrucks.com/vboard/s...d.php?t=367260
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Brake Booster
The booster and master from a '67-'70 C10 will bolt up with the addition of my brake booster bracket. The for sale thread for both '60-'62 booster brackets are in my sig line. Will you be converting to an auto trans or are you keeping the manual trans?
Re: Brake Booster
Thanks Captainfab, I already have an auto trans in her. When I bought the truck it came with power brakes but since the booster has gone bad and its hard to find the same one that worked before. Thanks I will look at those setups and see if I can make them work.
Re: Brake Booster
Captianfab, You wouldn't have a pic of how the pedal connects with the booster set up your showing with your bracket? I'm curious how the pedal attaches to the booster rod? Thanks
60-66 Nut
Re: Brake Booster
Regardless of which booster you use the pushrod will need to be lengthened to reach the brake pedal arm. Take a look at how ChiefRocka lengthened his starting at post #342 on this page.
http://67-72chevytrucks.com/vboard/s...533641&page=14 There are a couple other ways to lengthen the pushrod, but welding it together is the simplest.
Re: Brake Booster
Thanks for the input Captianfab, Another issue Ive ran into is the angle of the booster rod. When I connect the rod to the pedal the rod is at an angle and isnt depressing straight. Thats with the original bolt hole. Do you have any ideas?
60-66 Nut
Re: Brake Booster
More than likely the pushrod angle will be different with my booster bracket than with whatever setup you have now. It is recommended to drill a new hole in your brake pedal arm, 1" lower that the original hole.
Re: Brake Booster
Thanks for your help CaptainFab. I just had a random thought and maybe you could answer it for me. Do you need a proportioning valve with a 4 wheel drum setup to have power brakes?
60-66 Nut
Re: Brake Booster
No prop valve needed with 4 wheel drums.
