Old 11-14-2014, 05:19 PM   #1
ProudSoul
ProudSoul's Avatar
What bags are yall running?
Recently bagged the front end of my truck. I went cheap with the bags and bought some knock off dominator 2600 bags from airbagit/chassis tech. First set leaked at the crimp where the plate meets the rubber. They sent me 2 more and they do the same. So I'm sick of fiddling with cheap bags now!
I was thinking about firestone 2500s or airlift dominator 2500s for the front. I don't want a whole lot of lift and want to stay with the smallest diameter possible. I can't afford slam specialties so that's out of picture so what is everybody else running?
ProudSoul is offline   Reply With Quote
Old 11-14-2014, 09:09 PM   #2
mixermike
mixermike's Avatar
Re: What bags are yall running?
I have 2600 dominators on mine for over a year now, very happy with no issues. Gonna use them again when I bag my 63
mixermike is offline   Reply With Quote
Old 11-14-2014, 09:17 PM   #3
LVPhotos
LVPhotos's Avatar
Firestone 2600 on amazon for $69 each.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-14-2014, 09:42 PM   #4
hotrod66
hotrod66's Avatar
paper
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 11-14-2014, 10:55 PM   #5
ProudSoul
ProudSoul's Avatar
Sweet, I'll check that out. Any problems with your firestones?
Originally Posted by hotrod66 View Post
paper
Indeed, paper is better than plastic
Old 11-15-2014, 03:21 PM   #6
NEWFISHER
NEWFISHER's Avatar
Firestones. Have used the 2500 and 2600 5 and 8 diameter. I found the bigger bags ride better. I would recomend cupping or plating your arms to use the bigger diameter bags. Once and done
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 11-16-2014, 11:04 AM   #7
creep
Registered Loser
creep's Avatar
I am using Dominators 2600s on all 4 corners of my truck and they ride great. 1 bag has a slow leak at the top but not bad enough to discourage me from buying them again.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 11-16-2014, 08:46 PM   #8
Jeff La
So you would rather kill a tree than plug a landfill
Jeff La is offline   Reply With Quote
Old 11-17-2014, 12:12 AM   #9
NEWFISHER
NEWFISHER's Avatar
Here in the NW we harvest and replant trees. Its like gardening long term. We enjoy wood homes and the use of toilet paper knowing we arent killing trees, just rehoming spotted owls
GOD BLESS AMERICA!
Old 11-17-2014, 01:19 AM   #10
lowlife4life
lowlife4life's Avatar
slam specialty bags the new design doesn't grow in diameter and they have built in bump stops never had a problem, other than my own stupidity
lowlife4life is offline   Reply With Quote
