11-14-2014, 10:42 PM | #1 |
hydraulic clutch for newer 5 speed?
i have a nv3500 and want to put it in my 65 c 20. i want to see if any one has any ideas on how to adapt master to run the slave cylinder any help is appreciated.
Between saying and doing many a pair of shoes are worn out |
11-15-2014, 12:13 AM | #2 |
60-66 Nut
Re: hydraulic clutch for newer 5 speed?
I make a booster bracket with a hydraulic clutch conversion for the '63-'66's. Here is a pic of the kit. I just don't have a for sale thread yet.
11-15-2014, 10:42 AM | #3 |
Capt.
Is your clutch conversion bracket for the newer style hydraulic clutches, or the older original double master type? or both? Jim |
11-15-2014, 11:16 AM | #4 |
what booster do you use one off of a square body or a corvette style aftermarket?
11-15-2014, 12:14 PM | #5 |
HI guys this may help with your questions http://www.67-72chevytrucks.com/vboa...d.php?t=362375
11-16-2014, 01:18 AM | #6 | |||
60-66 Nut
If you are referring to the '60-'62 Chevys and '60-'63 GMC's, That is the first one with the hydraulic clutch that I started making years ago. See the link that jtrichard posted. It is also in my sig line.
