11-15-2014, 10:36 AM | #1 |
Education needed......TH350 tranny versus 700r4 tranny
Hi folks,
can anyone help explain to me what the benefits/differences would be between these two transmission please? Is it worth me putting a 700r4 into my 1955 2nd series 3100? At the moment she is running a TH350 mated to a 350 engine.... is it an easy straight forward swap or am i in for a load pain if i went for it? Many thanks in advance Mario |
11-15-2014, 10:42 AM | #2 |
Re: Education needed......TH350 tranny versus 700r4 tranny
The 700r4 is basically a TH350 with an extra gear.
It shouldn't be that bad of a change over as I don't think its electronically controlled. The length may be different so you'll need your drive shaft modified. Kim |
11-15-2014, 10:57 AM | #3 | |
it was the shaft i was worried about.....where i live there is no one that does these sorts of vehicles,so i feel it will end up being more hassle than i really need..... thank you for taking the time out to reply |
11-15-2014, 11:18 AM | #4 |
polishing a turd
I think it's about 1.25" longer (the 700r4) so you may need the driveshaft shortened
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
11-15-2014, 12:15 PM | #5 |
depends on how much you drive your truck and how much you like paying to fill the tank
with 25,000 miles on truk i think i have justified the extra expense of swapping from 350 to 700r4 the 200r4 is the same length as the th350 and will bolt right in the 700r4 will need the x-member moved and driveshaft shortened either one you need to find the right years, early years were unreliable, later years had computers you'll need to control the lockup on either one, many vendors have kits that can do this both also have a tv cable rather than the kickdown cable, the tv cable needs a bracket and mount on the carb again universal kits available to mount the tv cable
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-15-2014, 01:01 PM | #6 | |
thank you for giving me all that info Ogre |
11-15-2014, 02:13 PM | #7 |
Ok, what does the "tv" mean?
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
11-15-2014, 03:13 PM | #8 |
tv cable is throttle valve I do believe. the tv cable on the 700r4 have to be set up on carb end and adjusted correctly for them to shift right and last. the electronic ones are the 4L60E (E for electronic) ,if you have low rear axle gears 3:73,3:90 4:11(3:90 is in 55-59 trucks) and small diameter rear tires an overdrive definitely will help drop cruIse rpm. 3:73 gears in OD will be like 2:73-3:08.
11-15-2014, 05:33 PM | #9 |
11-15-2014, 05:43 PM | #10 |
11-15-2014, 09:28 PM | #11 |
lol wont shift very good with that tv cable .probably get lots of channels though.
11-28-2014, 01:12 AM | #12 |
Ogre, That is funny..... I really like that "tv" cable
11-28-2014, 03:05 PM | #13 |
I had a bunch of that tv cable stuff, so I took Ogre's advice and installed it in my truck. A very nicely coiled section, on the floor right above the tranny. It didn't work, the TH400 shifts just like it did before and disappointingly, still no OD. So, IMO it's now proven conclusively that it doesn't work.
11-28-2014, 03:57 PM | #14 |
57 channels and nothing to watch !
700r4 'early' trannys had mechanical shift, later are computer shifted. Some 'early' have mechanical speedometer drives, later ones are for digital speedometers, can be interchanged with corresponding parts.. |
11-28-2014, 07:44 PM | #15 |
the early ones with tv cable and mechanical shift are also the best for use in our old trucks
fwiw... i've never paid for cable tv, can't justify paying for commercials
11-29-2014, 01:46 AM | #16 |
""the early ones with tv cable and mechanical shift are also the best for use in our old trucks ""
That's what we put in the '51 - rebuilt with red line clutches and a thicker shift plate, and a frame mounted cooler. |
11-29-2014, 07:11 AM | #17 | |
11-29-2014, 07:32 AM | #18 |
Rottenwood Garage Member
If it is an around town periodic cruiser and the TH350 is already in it just stick with it. You wont need overdrive. If you are going to turn it into a pro tour truck or an interstate driven daily driver DO THE SWAP!
In addition a few thing to think about: If your truck does scream at higher RPM's it is way easier and cheaper to change the rear end to a higher gear ratio. If you are running the original rear and it was a 6 cyl truck its probably a low gear. Slap a car/truck 10/12 bolt in it from a junk yard or craigslist with a 3.08 or even a 2.73 and your golden. Your "off the line starts" will suffer slightly but now top end will be better. You will need to do the research to see what is the correct width rear. This could be done depending on brake condition for $100 to $300 and possibly a little perch welding and brake work. If you go with a 700R4/4R, you will need to find or build a good transmission, buy and or do the lock up kit, move back the transmission cross member or buy a new one, shorten the drive shaft, acquire a TV cable bracket and most importantly, if you know nothing about TV cables, have a local trans shop set the cable for you. You can burn up a 700 quickly if your shift points aren't set correctly. $700-$2000 As usual the above is just this mans opinion and we all know about opinions!
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
12-08-2014, 02:58 AM | #19 |
My 56 doesn't have a power train in it yet but I have a th350 in the shed, and a friend offered me a good 700r4 for $150. I'd need to have the drive shaft shortened and build a cross member either way I go. Would it be silly to pass up the offer or stick with the 350? My truck will mostly be a weekend cruiser but will see the highway occasionally.
Sorry if I'm jacking this thread but I figured I'd ask it here since you're all on the subject already. |
12-08-2014, 09:21 AM | #20 | |
700, for sure. Maybe, 3.23 gears too, like Ogre.
12-08-2014, 02:20 PM | #21 |
I'd use the OD transmission. It will work well, even in Helena.
When I lived in Hardin I had a '79 Monte with a 455 Buick, a THM400, 235/75 15" tires, and a 2.26:1 rear gear. That was a good combination for the highway. What's really important though is what condition is the trans in? Is it an early trans that doesn't have any upgrades? Has it been used for 200k and in need of overhaul? Has it been worked hard and put away wet too many times? IOW, be confident that the work to install the trans is worth it, and that you're not going to be replacing the unit shortly after the truck's on the road. Last edited by 1project2many; 12-08-2014 at 02:28 PM. |
12-08-2014, 07:42 PM | #22 |
ogre thinks you'd be silly to pass on it, but...
depends on your mpy (miles per year) and your expectations out of your truck weekend cruiser up to glacier or weekend cruiser to the local burger joint? 60 mph weekend cruising or 95 mph weekend cruising; face it, you live in montana i prefer the option to do both; cruise to glacier at 95 mph, if i so choose even michigan is thinking about bumping the freeway speeds to 80 mph either one needs the same basic mods to fit in a task force truck and again... but, the 700r4 will need modifications as in the lock up kit, there are a couple of versions of the 700r4; one has a tv cable and controller (good) the other is full computer controlled (bad)
12-08-2014, 09:31 PM | #23 | |
12-09-2014, 07:41 PM | #24 |
thanks 1p2m
my wife says i'm a man of few words all the wrong ones
12-09-2014, 09:41 PM | #25 |
The condition of the trans is truly unknown, my friend bought a 90s caprice with the LT1 in it and crashed the car shortly after he got it. I drove the car and seemed to shift fine but it's been a few years. I'll go with the 700r4, too many votes and I know I'll regret it later on. For $150 for a working trans and I'll have to install either trans anyway, it seems like a no brainer. Even if I have to rebuild it later on that would be OK, I'm doing a fresh complete build on my vortec 350 too. Shall be like a new-old truck when I'm through
