Old 11-15-2014, 12:46 PM   #1
rcg66
rcg66's Avatar
Lowered Coil Springs
I am thinking about dropping my 66 longbed using coil springs. I am looking at 2" in front and 4" in the back. I am wondering if I am going to run into any surprises if I go this route. I know I will have to modify the panhard bar (right?), but is there anything else I might be running into? Has anyone else gone this route and wish they hadn't? Thanks for any input anyone can provide.
rcg66 is offline   Reply With Quote
Old 11-15-2014, 05:46 PM   #2
Mathew21
Mathew21's Avatar
Re: Lowered Coil Springs
You will probably need shorter shocks for the front. The rear as you mentioned you are going to have to rework the panhead bar or buy an adjustable one. You will also need shorter shocks in the rear and I would consider installing shock relocator kit in the rear.
I recently lowered mine. I used 2.5" drop spindles and 2" lowering springs up front. 4" lowering springs in the rear. Lowering shocks in the front and lowering shocks, shock relocater and custom panheadbar in the rear.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 11-16-2014, 09:13 AM   #3
66BigBackWindow
I am looking at the same set up on my 66. After getting some input from other members I will likely go with a complete kit from CPP, here is their link. http://www.classicperform.com/
You can pick and choose parts or they do have a complete kit with springs, new shorter shocks, and new shock mounts. They also have adjustable panhard bars available. I would also take the time to put in new trailing arm bushings and look at all those other little suspension bits at the same time.
66BigBackWindow is offline   Reply With Quote
Old 11-16-2014, 10:26 AM   #4
4shongo
I just installed a CPP 3"/4" spring drop kit yesterday. Installed the adjustable pan-hard bar, relocation brackets, and front re-enforcement brackets. Nice kit, installed the same kit on my 72 Suburban. Give Jeff Norton at CPP a call, ask for your forum discount. Good luck
4shongo is offline   Reply With Quote
Old 11-16-2014, 10:49 AM   #5
duallyjams
duallyjams's Avatar
ECE makes a nice kit also.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-16-2014, 01:44 PM   #6
MisterC
MisterC's Avatar
ECE 2/4 coil spring drop with Porterbuilt adjustable trac bar and shock relocation kit. Rides like a dream.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 11-16-2014, 01:54 PM   #7
grs
I lowered my 64. 4 inch lower rear coils. I did not use shock relocation kit. I did use a duel adjustable track bar from CCP.
grs is offline   Reply With Quote
Old 11-16-2014, 03:13 PM   #8
Grizz1963
Grizz1963's Avatar
Just finished mine over here in England.
2" dropped springs, shocks all round and another 2" lowering blocks in the rear.
I LOVE IT !!!
Take a look in my build thread how we got there.....
http://67-72chevytrucks.com/vboard/s...d.php?t=585901
This was 18 months ago on very tired shocks and springs, both cut and heated..... rode like a drunk duck.
This was yesterday......
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 11-16-2014, 04:32 PM   #9
rcg66
rcg66's Avatar
Thanks for all the replies. I am really trying to get by with the lowest expense possible for this project. For the panhard bar, I plan on cutting and sleeving it when I get the rear centered up. I didn't really want to have to buy new shocks because I just bought the ones I have on it now, but don't think I have any other option than to go with shorter shocks.
Old 11-17-2014, 10:20 PM   #10
slowGN
slowGN's Avatar
Not to hijack..
Grs. What did you do to the front. How much did you lower it. Awesome looking truck
slowGN is offline   Reply With Quote
Old 11-17-2014, 10:46 PM   #11
grs
Originally Posted by slowGN View Post
Not to hijack..
I installed 2 and 1/2 inch drop spindles. Disk brakes on the front.
Old 11-18-2014, 12:16 PM   #12
waspp
waspp's Avatar
I used 2.5 inch drop spindles and 1 inch drop coils in front and 4 inch drop coils in the rear and had no issues. I used the stock track bar but did go with a set of lowered shocks.
waspp is offline   Reply With Quote
Old 11-18-2014, 09:30 PM   #13
gimmy 64
for the rear shocks use your front shocks put them on the back and just buy front lowering shocks.
gimmy 64 is offline   Reply With Quote
Old 11-19-2014, 07:13 PM   #14
scott657
scott657's Avatar
Not to hijack..
agreed PERFECT stance
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
scott657 is offline   Reply With Quote
Old 11-19-2014, 08:17 PM   #15
Ratpin
Ratpin's Avatar
Wicked looking truck! Love the stance.
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 11-19-2014, 11:03 PM   #16
rcg66
rcg66's Avatar
That is a great idea! Would they really work that way?
Old 11-20-2014, 04:36 PM   #17
Mathew21
Mathew21's Avatar
I also read you can put stock front shocks on the rear of a lowered truck. I bought a set of stock height shocks and installed them on my truck that has 4" lowering springs in the rear. To me it felt like the shocks didn't have enough travel. I ended up switching them out for a longer shock. But every truck is different and everyone has different results.
