Old 11-15-2014, 03:31 PM   #1
dfrank
dfrank's Avatar
Tremc TKO 600 IN 4x4
I have an 86 chevy k10 shortbed I am going to start restoring soon. It has a 383 stroker with th350 tranny. I would like to put in a tremec tko 60p 5 speed and was wondering if that transmission would work with 4wd and what I would need to connect the transfer case to it. Any other info on what i would need for the swap would be greatly appreciated. Thanks!
dfrank is offline   Reply With Quote
Old 11-17-2014, 03:59 AM   #2
Cabnchassis
Re: Tremc TKO 600 IN 4x4
http://67-72chevytrucks.com/vboard/s...d.php?t=473871
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 11-18-2014, 03:18 AM   #3
andrewmp6
I don't think you can mount a t case to the trans.The only way i know to do this is run a divorced t case.Or run a different trans like a nv4500 or nv5600 if you want a 6 speed.
andrewmp6 is offline   Reply With Quote
