11-15-2014, 03:37 PM | #1 |
GMC Headlight Trim Surround Question ?
This is for the 4 eye experts, I found a real nice pair of GMC headlight trim surrounds "Rings" at a local wrecking yard. They cleaned up real nice with a little metal polish. When I went to install them, no way will they fit ? I did not realize there was a difference between the early slant nose models and later ones? I also found out they are not Stainless, I was under the impression GMC'S had Stainless Grills and Chevys had Anodized Metal?
71 C-20 07 Magnum RT AWD |
11-15-2014, 03:41 PM | #2 |
member #16
Re: GMC Headlight Trim Surround Question ?
GMC's were chrome plated steel grills.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
11-15-2014, 06:43 PM | #3 |
I had my rechromed, so I've got to assume John is correct. My '70 doesn't have rings per se, it has a "plate" with two holes (for the headlights). Sorry the outboard one is a little crooked, I have to add a notch to the bucket to get the aftermarket lamp assembly properly vertical.
11-16-2014, 10:32 AM | #4 |
I had a 71 GMC. The grille, headlight rings and "hood bar" were all just chrome plated steel. Im not sure if the slant hood models were different from later models. Have you double checked to be sure you don't have them swapped side to side or upside down?
11-16-2014, 11:08 AM | #5 |
Trying to confirm if they are the same between 67 & 72 ? I tried to mount the pair I picked up at a salvage yard but had no success. Trying to mount them on a 71 ? I had a 68 with painted "Plates" "Surrounds" "Rings" what ever you call them and if I remember correctly, they looked thinner front to back ? Anyone know for sure? Part numbers ?
11-17-2014, 04:43 PM | #6 |
Still trying to determine if the trim is same or different between 67-68 & later years ?
11-17-2014, 11:34 PM | #7 |
Have you checked the parts book? Find it in the book for your year, and the year you wish to install it on, and see if its the same number.
I would imagine there are chrome and bare steel (for painted front ends), but other than that I cannot see why there'd be more than those two variants (for GMC, anyway) each year.
11-18-2014, 04:29 PM | #8 |
Use an SOS pad to clean them.
1968 Custom SWB, 327/3 speed OTC 1969 CST LWB, 402/400 1970 CST LWB, 402/400 1970 Sierra Grande LWB, 350/350 1971 Cheyenne LWB, 350/350 1972 Cheyenne Super LWB, 402/400 1972 Sierra Grande LWB, 402/400 1979 Silverado LWB, 350/350 1984 Suburban 1990 454 SS 1991 Silverado, X-cab, 4.3/5 speed Getrag 2005 Silverado Crew Cab Corvettes: 75, 77, 78, 93, 96 |
11-18-2014, 04:49 PM | #9 |
Are you referring to the headlight bezels? LMC has them under the same PN for 67-72. Those are for the chrome ones. That's not to say GMC didn't use a slightly different grille/covers for the non painted (doesn't make sense, but possible...)
...and pics always help! A LOT!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-18-2014, 05:15 PM | #10 |
Roadtrip!
I think they all should interchange. Did you personally pull these off of a gmc yourself? I am thinking they may be from a car that look similar. I think pontiac had bezels that look similar.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
