Old 11-15-2014, 05:22 PM   #1
Gregski
Post Whore
Gregski's Avatar
Firewall Ground Copper Ribbon Wire - Where does it connect to?
Apologies, I hate asking these types of questions, but I searched the factory manual back and forth and though I thought I've seen it somewhere in there for the life of me I can't find it now.
So please, where does it connect to on the motor?
The end part seems too narrow to connect to the cylinder head rear accessory hole.
Pic attached
1974 GMC 1/2 Ton 2WD four speed manual, 350 V8, Quadrajet, no AC truck
Gregski is offline   Reply With Quote
Old 11-15-2014, 06:00 PM   #2
geezer#99
geezer#99's Avatar
Re: Firewall Ground Copper Ribbon Wire - Where does it connect to?
Bolt that ground strap right back onto the back of your head. Cylinder head that is!!
Old 11-15-2014, 06:04 PM   #3
greg64
greg64's Avatar
On my 6 cyl, it gets caught under a valve cover bolt, which are only 1/4".
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 11-15-2014, 06:04 PM   #4
ont_guy_38
ont_guy_38's Avatar
I think the earlier models actually attached to the valve cover bolt.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 11-15-2014, 06:13 PM   #5
cadillac_al
It hooks on a valve cover bolt.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 11-15-2014, 07:14 PM   #6
Greenlee
Greenlee's Avatar
On my truck (TBI 350) it bolts to the back of the engine as was mentioned above. It's pretty difficult to get to. The distributor is in the way and you can't see it withou a mirror.
Greenlee is offline   Reply With Quote
Old 11-15-2014, 07:27 PM   #7
Gregski
Post Whore
Gregski's Avatar
Originally Posted by geezer#99 View Post
bolt that ground strap right back onto the back of your head.
lmao
Old 11-15-2014, 07:29 PM   #8
Gregski
Post Whore
Gregski's Avatar
That was my thought also, I bolted it to the inside valve cover bolt instead of the outside one so it wouldn't be too close to the spark plug cables.
Thank you all for replying
Old 11-15-2014, 07:32 PM   #9
E.D.75GMC
E.D.75GMC's Avatar
On my 75 it's bolted on with the valve cover
E.D.75GMC is offline   Reply With Quote
