Old 11-15-2014, 08:51 PM   #1
paul mora
Ls intake lq9 6.0
I got my hands on a professional products Ls 2 intake and when I set it in place on the motor it does not seem to fit Do truck motors use different size intakes I have a2005 6.0 lq9
Pulatoy
paul mora is offline   Reply With Quote
Old 11-16-2014, 10:44 AM   #2
homemade87
Re: Ls intake lq9 6.0
There are only two different intakes for those ls motors . The ls2 cathedral port and the ls3 rectangle port. Have the heads been change. Post a picture of the engine and intake.
homemade87 is offline   Reply With Quote
Old 11-16-2014, 02:56 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
There are more than 2 intake types, but your correct that there are only two port Styles. Rectangle port and Cathedral port.
What about it isn't fitting? Are the runners not lining up, or something else?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-16-2014, 10:52 PM   #4
crazy longhorn
Fabricate till you "puke"
The coolant (steam lines), were not hitting on the bottom of the intake? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-17-2014, 10:04 AM   #5
Wasted Income
Boosted Member
Wasted Income's Avatar
Don't forget about the LS7, which is also unique.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-17-2014, 05:39 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Ya but doesn't the LS7 use a rectangle port also? You can put the LS7 intake onto an LS3. The runner design is made for higher cube cars, but I don't know if I'd say its another port type. It'll interchange, just not necessarily make the best power on a sub-400ci engine
Old 11-17-2014, 06:59 PM   #7
homemade87
The ls7 will not fit the ls3. Different port locations.
Old 11-17-2014, 11:00 PM   #8
paul mora
I feel like a idiot about the fit but it was hitting a bracket on the rear and would not drop down so that problem is solved. Now another problem the heads are cathedral and the intake is a rectangle. The catalog says it is for a ls2 but I thought Ls2 heads are cathedral. Will this work. On the factory intake the top is not a full opening it is where the injector sit and in the aftermarket the injector is mounted above the rectangle in a hole of its own pointing into the top of the cathedral port so it looks like it should inject at the same hole.
Pulatoy
Old 11-18-2014, 08:37 AM   #9
homemade87
No , It will not work . Not sure about the intake. Not familiar with professional products. If it is a rectangle it is for a l92/ls3. Ls2 is cathedral
Old 11-18-2014, 09:55 AM   #10
Wasted Income
Boosted Member
Yes, it does use a "rectangle" port, but LS7 heads are completely different than LS3 heads...larger intake and exhaust ports, different valve angle, larger valves, and as homemade87 pointed out, the port and intake manifold bolt spacing are different.
Turbo diesel
Old 11-18-2014, 09:59 AM   #11
Willie Makeit
Willie Makeit's Avatar
No sir. The shape of the port is quite different.
Left to right:
CATHEDRAL
RECTANGULAR
LS7
Willie Makeit is offline   Reply With Quote
Old 11-19-2014, 07:36 PM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Interesting as I'm seeing more and more threads about builds boring out LS2 and LS6 blocks to about 4.1 so the valves aren't shrouded, and having it work. I'll have to qualify that these have all been custom blocks, so if there is a bolt pattern mismatch they might be handling it in the build (but I haven't seen mention of it).
Old 11-22-2014, 08:43 PM   #13
paul mora
Are all head with cathedral ports the same or are the truck motors Lq9 different cathedral then the non truck cathedral or are the heads identical
Pulatoy
Old 11-23-2014, 10:59 AM   #14
Hart_Rod
Hart_Rod's Avatar
I'm pretty sure all stock cathedral ports are the same.
Hart_Rod is offline   Reply With Quote
Old 11-23-2014, 01:24 PM   #15
paul mora
The new manifold ports are the same configuration and they match except on the manifold they are about1/2 inch shorter at the bottom
Pulatoy
Old 01-08-2015, 06:54 PM   #16
Gooker928
That intake won't work. I'm curious as to why you didn't keep the truck intake?
They make way more torque.
Gooker928 is offline   Reply With Quote
