11-15-2014, 09:25 PM | #1 |
Leaking coolant - help!!!
I drove home the other day and smelled what I thought was coolant. I parked my truck and came out about a half hour later to find a puddle under the passenger side by the firewall. I immediately thought I must have lost my heater core.
I finally got around to pulling it out today (about a week later) and it still looks good. I ran some air through it and could not find a leak and then filled it with water and could not find a leak. I got under the truck and could not find any leaks in the lines or anything. What else could it be? **** Also, I have not been getting any heat from the truck lately so that also made me think the heater core was bad.
1973 Chevy K20 |
11-15-2014, 11:11 PM | #2 |
Robert Olson Transport
Re: Leaking coolant - help!!!
check for a pinhole in the hoses.. especially where they connect
11-16-2014, 06:37 AM | #3 |
Any green oxidation on the copper nipples of the heater core or elsewhere on the core? I would check right after parking after a long drive and check closely with a flashlight and inspection mirror. Something leaking that much should be noticeable at its source.
11-16-2014, 08:25 AM | #4 |
May still be bad. Lost mine on Friday. Current only leaks under pressure.
Mine leaks when I shut the truck off after driving, when the pressure would be highest. I also get the "foggy window" thing. Currently only leaks when I shut the truck off. Obviously I also can't use the heat and am stuck with driving with the wing window open, luckily it's not my daily. I may get lucky that it's only a hose, but not holding out hope as the HC is 25 yrs old.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
11-16-2014, 12:09 PM | #5 |
Just here to tinker
Sometimes a solder joint in the heater core will only leak when it is hot due to expansion. Replace it, you're there anyways.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
11-16-2014, 02:05 PM | #6 |
Yeah, I think I will just replace it. Its only $25.
1973 Chevy K20 |
11-16-2014, 06:37 PM | #7 |
Replace it any way got it out 25 bucks and your heat will improve.
