Big block in a low hump
Is it possible to put a big block in a low hump cab 2wd? I was just wondering. My engine took a s%$t and I may have a chance to get a big block. JIM
68 short fleet with 71 front clip 2wd jaguar blue ![]() 99 chevy ext cab shrtbed z71 loaded ![]() 99 chevy swb fleetside(daily driver) ![]() Sparks, Nevada |
i thought the hump would only effect the tranny. i probably dont know much though. lol.
'67 c10 350/th350 |
Gotta Startem Early
The only effect should be from the Tranny if the engine is in the V-8 position.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
its all about the +6 inches
From whats been said here before, yes, if it is up front instead of in the I-6 position...and it may be kinda tight.
Highboy, the big block is a bit taller which raises the front of the tranny up a bit needing a bit more clearance, that is why big block trucks had hugh hump trannys. |
I have an original 69 2 wd frame with 396/th400. Cab was a low hump. You just need to mount the big block in the forward mounting holes of the front cross member. It is predrilled for this application. Bring on the BB !!
69 GMC K10 ..some restoration required....still.. ![]() |
There were some made like that, just like my V6/TH400 GMC...with a high hump. No one can explain it.
i got the high hump. i think.
'67 c10 350/th350 |
This is a low hump 71 that had a t350/350 combo.....it now has the ZZ502/T400. No mods....no clearance problem
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
huh ???
I put a big block in my 72. It was originally a small hump 350/th350 truck.It now has a 71 402 and a 700R4 using the small block engine stands...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
![]() Join Date: Dec 2002
my '71 has 402 eng with 400 trans and with low hump floor
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
Thanks for all the info guys. Very well appreciated. JIM
