Old 11-17-2014, 05:06 PM   #1
wpotter
wpotter's Avatar
68 c10 seat cover pattern pictures
I am in need of an original seat cover photo to show my upholstery shop. Also could use measurements of how far apart the seams are. Original vinyl door panel pictures and measurements would be cool to. Thanks for any help.
Never a failure, Always a lesson!
1968 Chevy SWB Fleetside ECE 4/6 327/350
1987 Chevy V20 Scottsdale 4X4 350/400 4.10
1987 Chevy Custom Deluxe SWB 305/7004R4
1991 Suburban Silverado V1500 4X4 350/700R4
2015 Chevy Crew Cab SWB (Daily Driver) 5.3
wpotter is offline   Reply With Quote
Old 11-17-2014, 06:08 PM   #2
ho70
ho70's Avatar
Re: 68 c10 seat cover pattern pictures
just check a LMC or classic industries catalogue online. Might be cheaper to buy one then get one made
ho70 is offline   Reply With Quote
Old 11-17-2014, 06:27 PM   #3
sboris
sboris's Avatar
As far as i know they dont reproduce the 67-68 seat cover. Thats what i ran into. Depending on your trim level, the vinyl is stamped. Can take a pic later if you still need it. My old one is the stamped vinyl.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 11-17-2014, 06:44 PM   #4
wpotter
wpotter's Avatar
I have not been able to find a 67-68 bench seat cover, only buddy buckets. If you can send a picture later that would be cool. Plus I want to use the same material for seat cover and door trim panels so they match.
Old 11-17-2014, 08:08 PM   #5
sboris
sboris's Avatar
The center is 10 1/2 inches between the pressed marks. The side measured 3 inches from the bead. Hope this helps. I color matched mine best i could, but did not get this pattern duplicated. Good luck.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 11-17-2014, 08:15 PM   #6
sboris
sboris's Avatar
Oh and cant help you on the panels, mine are metal.. Sorry. If needed, i could probably cut out some samples..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 11-21-2014, 10:08 AM   #7
Steve Hafner
Steve Hafner's Avatar
Here are few pictures I've saved of what were said to be original cloth / vinyl 68 seats:
Steve Hafner is offline   Reply With Quote
