Old 11-17-2014, 09:24 PM   #1
Nicholsea1
68 swb - lowering 6" in the front- too much?
Thanks for all the help everyone!
I am thinking about using 3" lowering spindles and I already have CPP 3" lowering springs. Will I run into any issues with a total 6" drop?
Nicholsea1 is offline   Reply With Quote
Old 11-17-2014, 11:16 PM   #2
68bowtie
68bowtie's Avatar
Re: 68 swb - lowering 6" in the front- too much?
lots of info on the board, do some searching...
http://67-72chevytrucks.com/vboard/s...d.php?t=530394
http://67-72chevytrucks.com/vboard/s...d.php?t=199893
http://67-72chevytrucks.com/vboard/s...d.php?t=321067
Old 11-17-2014, 11:21 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
You a-arms will be about 2" from the ground with a stock crossmember.
Keith
Convert to disc brakes.
Old 11-17-2014, 11:44 PM   #4
72BigBlockBurb
72BigBlockBurb's Avatar
Probably closer than 2"...I think that's the same drop put on my truck prior to purchase. It is actually lower to the ground than our 2000 corvette! Found that fun fact out when I went to the only place in our area with an oil pit that the vette barely clears...the truck needed about an inch more of clearance. The other issue is that you'll find highway transitions can be real "fun" with the setup...I-10 between the TX state line and NOLA was quite a bit of adventure in spots...
http://67-72chevytrucks.com/vboard/s...d.php?t=545293
Current pic to follow later.
1949 Chevrolet 1/2 ton panel
1950 Chevrolet 1/2 ton pickup-ex Army base veh.
1967 Chevrolet short stepside shop truck
1972 402BB Suburban-Finally got her back!
1982 Mecham Racing Firebird #21
2009 GT1 Corvette
2000 Corvette convertible
72BigBlockBurb is offline   Reply With Quote
Old 11-18-2014, 06:45 PM   #5
kitsbeach
kitsbeach's Avatar
Would a porterbuilt or no limit crossmember give more clearance.?
I'm going for 5" static front drop. Thinking 2" modular spindles and 3" drop springs....
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 11-18-2014, 07:04 PM   #6
lolife99
lolife99's Avatar
Edit:
Need to learn how to read. Ha
Keith
Old 11-18-2014, 09:21 PM   #7
kitsbeach
kitsbeach's Avatar
No.
The a-arm pivot point is still the lowest part of the truck.
You need to move the crossmember up in the frame to gain ground clearance.
aka a Dropmember, sectioned crossmember or frame Z.
Thanks Keith...so ok it makes sense to me that the a-arm pivot will be lowest point...so how does the dropmember give us more clearance.? won't the a-arm pivots still be the lowest point even with the drop member.?
I can see how the drop spindles will move the a-arms closer to the road, but don't get the drop member improvement...
Kitsbeach (Ken)
Old 11-18-2014, 09:40 PM   #8
lolife99
lolife99's Avatar
Sorry,... I mis-read your question.
The Dropmember DOES move the crossmember up in the frame.
Level 1 moves the crossmember and a-arms up in the frame 1".
Level 2 moves the crossmember and a-arms up in the frame 2".
Level 3 moves the crossmember and a-arms up in the frame 3". (Extreme Dropmember version)
http://pbfab.com/67-72-gm-truck
Keith
