looking at a 72 k10 need help
im looking at a 72 chevy swb k10
truck has factory tach tilt and air conditioning any thing I should look for before I purchase needs rockers cab corners and one bedside also cab supports need some attention any idea what to offer 350 / 350 all original or looks to be |
Re: looking at a 72 k10 need help
Really tough to give a value without pictures. What you have described is a $2,000 - $6,000 truck IMO.
Check the numbers, do they all add up? Frame VIN matches the VIN plate? SPID looks original and has the options you describe on it? Is the paint original? If not, is the new(er) paint hiding anything? More importantly, what are you looking for? A truck to completely customize? If so, the numbers may not matter.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
it all matches originaly orange but painted maroon thanks
rust is the thing that takes so much time and $$ to fix
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
![]() Join Date: Dec 2013
Look for frame rot or snow plow use /bent frame .What do they want for it ?
pics
ignore the jeep
![]() Join Date: Jun 2000
Looks good in the pics, but you don't say whether it runs and drives. With a flat tire, maybe it doesn't drive too well! A running and driving truck will make a huge difference on price.
As others have said, rust/rot can make or break it, and it really depends on what the intended use is. Resto or just drive it. If resto in planned, look for the best rust-free body you can afford. If rust/rot is visible, assume it's far worse underneath. |
![]() Join Date: Jan 2002
Wow that would be the most desirable 72 4wd if its original. Cheyenne super short boxes are few and far between
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
All about them K’s
![]() Join Date: Jun 2014
I'm assuming since you say it was orange that you've got what appears to originally have been a hugger Cheyenne Super k/10 with tach tilt etc. very nice find. By the pics the rockers are still there and I only see a little bit of rust in the wheel arch on the drivers bed side. Obviously pics only tell half the rust/rot story, but that looks to be a very nice find to me. Id buy it if I could.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Very desire able truck for sure.
But the cancer that I can see in the pictures catches my eye as to what lies unseen? Good luck! |
x 2 the supers are not too common in a 4x4
#13 |
That thing looks like it could be really rusty. But, maybe the tailgate and wheel arch are truly the only rusty places???? You will need to check the body over real well.
As others have said, you don't see many 4x4 SWB Cheyenne Supers. Can you post a picture of the SPID? My rust tolerance would increase greatly if that's a true Cheyenne Super.
#14 |
id say it all depends on how bad the rust is if its not bad id say 4-5k but if panels need replaced id say around 3k
#15 |
runs just been sitting for a while the tires are junk
rust really isn't that bad though been under and the cab mounts need some attention but not horrible |
#16 |
Post a picture of the SPID, let's see what it really is. You might have a heck of a truck on your hands.
#17 |
Carpe manana
![]() ![]() Join Date: Dec 2010
No rear cargo light = not an original Cheyenne cab let alone a super
As stated, SPID pics and one of the LH pillar VIN tag would help.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#18 |
Look very carefully at what it was and its current condition. Not convinced it is a true Cheyenne Super from the provided pictures.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#19 |
thanks for the help
