Half a bubble off!
Failing memory and no search function mandate that I ask what backspacing is needed on my '71 2wd with disk/drum combo? I am about to buy some new wheels, and they are only offered with 4" backspacing. I don't think that is a problem, but thought I better just double check with the experts. Thanks, LB.
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
miss the search
Standard backspacing is 4-1/2". 4" will just put your tire closer to the fender lip. If the tire isn't too wide and you haven't lowered your truck too much, it shouldn't be a problem. Good luck, Scott
Silence is golden, duct tape is silver. - Scott |
Half a bubble off!
Thanks Scott, that's what I wanted to hear, and I have the room, so baby can get some new shoes, lol!
67-72 Addict!
LB, what kind of rims and tires are you going with?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Half a bubble off!
The Vision 57 Chrome Rally's, with same tires (almost new Toyo's).
