how to install fender badges WITHOUT removing fender
How best should I go about installing my Scottsdale badges without pulling the fenders all the way off? I cant see any easy way to do it
At the body shop.
Re: how to install fender badges WITHOUT removing fender
Double sided tape.
" That didnt make it any newer " " Dont antique the equipment " |
For lineside repairs we used to use a small feature called a "barrel clip".
It was a small, rounded clip that fit in the round hole in the fender and the post of the emblem was inserted and retained in the clip. I do not know if they are still available or where to find them but they seemed like a standardized (not GM specific) part. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Dang it.
I was hoping there was a way to just pull the bottom and reach up, then realized how far up the fender it is. That barrel clip.is it like this? http://www.etrailer.com/Merchant2/gr...-0244_1000.jpg |
Yes...most body shop supply (or bodyshops) will have a variety of them.Put a blob of seam sealant on as you put the clip in as they can scratch to bare metal where they go in...and start a rust streak.
#6 | |
Are the original emblems still on? Do you need a suggestion on how to remove them without removing the fender? ![]() K
Sidebar (just for discussion purposes):
I never liked the fender emblems, especially the Scottsdale version with the yellow paint. When I re-did my truck I filled the holes and did not reinstall the emblems. Sounds like you already have the holes but if (on the offhand chance) you didn't want to reinstall the emblems here is what we did on the CUCV models: they didn't get fender emblems either so we plugged the holes with a small plastic rivet. I noticed the other day I still have the special installation tool, which I thought might come in handy for something someday (it hasn't). So that would be a discreet way to plug the holes without having to fill and repaint, if a person was interested. K
subscribed
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
#9 | |
I removed them before paint but now that the fenders are lined up, I was trying to keep from pulling them, thanks for all the help |
#10 | |
Very good - K
Care to share your expertise on removal of the badges? I love them so I want to keep them in good shape without breaking them off for paint.
Long live SLIM ------------------ At least try to buy American ![]() |
#12 | |
My technique for removing them (with the fender on) would damage them. K
#13 |
I used a couple dabs of seam sealer by each post with no clips. It's been over a year and no problems with them coming off.
#14 |
I plan on having all of the fender trim and side trim and tailgate trim holes MIG welded closed prior to my repaint. Here in the desert, I have had all of the trim crack and fall off over the years. The unadorned look is favored by youngsters out here, especially on slammed trucks - 20 or larger wheels and wide/flat looking tires - not my style but I do like the clean look now.
#15 |
I'll take that suggestion for removing the old ones without taking the fender off. I don't mind if they get damaged in the process. Just don't want to mess with the paint.
Thanks! |
#16 |
I would to hear your method as well, I see lots of fender emblems in local junk yard I would like to get but the pot metal breaks easily with to much force.
79 Chevy 2wd BIG10 350 TH400 |
#17 |
Post Whore
![]() ![]() Join Date: May 2015
I got mine off with the fender in place....I used a brass putty knife and a deadblow ...got putty knife behind the emblem where the stud is ..my emblems were a little loose so that helped...pop the handle of the putty knife with the hammer and it sheared the stud off clean...I was painting truck so wasn't worried about skinning the paint....I put them back on with 3m emblem tape...
#18 |
#19 |
I have a 1977 GMC Sierra I put a screw in the dot of the (I) so I can take the emblem on and off every time I wax the truck .
