Trouble code P0174
I have been working on this for a few weeks and would appreciate if I could run this past you guys. Originally I was getting P0151, P0154, P0158,& P0174 After working on the truck doing the work below and sealing the resonator to the throttle body with a little RVT (new resonator $200.00) The MIL light does not come on but the P0174 does not go away.
So far I have replaced the fuel filter cleaned the mass air flow sensor, Checked the mass air flow sensor with a scan tool as per my Haynes repair manual. I bought a scan tool and am learning how to use it here is a scan that I did today. Number of DTCs stored in this ECU 0 Fuel system 1 statusOL Fuel System 2 statusOL Calculated LOAD Value(%)2.4 Engine Coolant Temperature(。C)89 Short Term Fuel Trim -Bank 1(%)0.0 Long Term Fuel Trim - Bank 1(%)16.4 Short Term Fuel Trim -Bank 2(%)0.0 Long Term Fuel Trim - Bank 2(%)25.0 Intake Manifold Absolute Pressure(kPa)30.0 Engine RPM(rpm) 628 Vehicle Speed Sensor(km/h)0 Ignition Timing Advanece for #1 Cylinder(。)23.0 Intake Air Temperature(。C)24 Air Flow Rate from Mass Air Flow(g/s)5.51 Absolute Throttle Position(%)0.0 Location of Oxygen SensorsB1S12--B2S12-- Oxygen Sensor Output Voltage Bank 1-Sensor 1(V)0.025 Short Term Fuel Trim Bank 1-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.050 Short Term Fuel Trim Bank 1-Sensor 2(%)N/A Oxygen Sensor Output Voltage Bank 2-Sensor 1(V)0.420 Short Term Fuel Trim Bank 2-Sensor 1(%)0.0 Oxygen Sensor Output Voltage Bank 2-Sensor 2(V)0.930 Short Term Fuel Trim Bank 2-Sensor 2(%)99.2 OBD requirements to which vehicle is designedNot OBD Power Take Off(PTO) StatusOFF ---------------------- I'm thinking I have some kind of vacuum leak. If you all concur What is the easiest way to smoke test? Thanks in advance Rick
05 Silverado 2500HD. 6.0 engine |
| Bookmarks |
