Old 11-18-2014, 05:12 PM   #1
Guy Dudebro
Trouble putting on oil pan screws
I recently removed my oil pan from my 67 c10 to replace the gasket. But I didn't remove the engine. I took off the engine mount bolts and have the engine jacked up a few inches after removing the pan and putting on the new gasket.
BUT my fingers are too big to secure the screws in some of those tight spots. I've tried an extended 7/16 socket but it doesn't have enough grip to secure the screw in the hole so I can tighten. Are there any special tools or tricks to get the oil pan back on?
I bought a Felpro so I have the snap ups on there. Just can't secure all the screws.
Guy Dudebro is offline   Reply With Quote
Old 11-18-2014, 05:15 PM   #2
cdowns
cdowns's Avatar
Re: Trouble putting on oil pan screws
Get modeling clay to help secure bolts to start them on there way
Old 11-18-2014, 05:26 PM   #3
john
member #16
john's Avatar
I usually use a piece of paper on the socket and push the bolt in. if it is still loose double the piece of paper.
john is offline   Reply With Quote
Old 11-18-2014, 06:35 PM   #4
Guy Dudebro
So the paper will keep it strong and steady so you can screw in?
Old 11-18-2014, 08:44 PM   #5
Grumpy old man
Grumpy old man's Avatar
Even a small piece of paper towel stuck in the socket will do the trick !
Grumpy old man is offline   Reply With Quote
Old 11-18-2014, 08:48 PM   #6
hamjet
hamjet's Avatar
I use masking tape...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
