Old 11-18-2014, 09:35 PM   #1
1947ratrod
1958 chevy hot rat rod
I took a truck on trade some one put a front stub on it they also the rear end out of the same car
the truck came from south Dokota very little rust on it some in the back of the cab and one spot in the front dog leg other wise good the front fender has a small spot
it had a small block in it but it was stuck from sitting so long didn't matter I'm going to put a diesel in it any way
I have a 4-53 Detroit diesel to put in it but I might have to switch frames cause of the weight of the diesel I don't think the front end will take the weight of it might have to switch it to a 1/2 ton frame out of the late 70s to the 80s
unless I sell this truck and buy one that no one switch the frame on it
1947ratrod is offline   Reply With Quote
Old 11-19-2014, 09:45 AM   #2
Kim57
Kim57's Avatar
Re: 1958 chevy hot rat rod
Welcome.
Sounds like a cool project.
Is the diesel heavier than a big block? If not it should work O.K. with the right springs and shocks.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-19-2014, 05:02 PM   #3
1947ratrod
the 4-53 are around 1200-1300 pounds so they are a lot heaver then a big block
Old 11-19-2014, 07:25 PM   #4
lower50's
lower50's's Avatar
I think the stock frame would be ok, if you box it and add some cross members. Then use all grade 8 bolts for suspension. Going to be a sweet build.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-20-2014, 07:52 PM   #5
1947ratrod
the front frame part is not stock that is what is bugging me it is a mid 80's car frame I know the rear end will not hold up to it
Old 11-21-2014, 09:33 PM   #6
lower50's
lower50's's Avatar
Oh ya that's a tough one. Maybe frame swap would be best plan. Just use the body you have since it's in good shape. My 2 cents. I'm using a s-10 frame boxed and extra cross members for my 7.3L diesel
1951 MG TD
Old 11-21-2014, 09:55 PM   #7
1947ratrod
I also bought a 1963 chevy long box siting on a 1975 3/4 4x4 frame I might put my diesel in that
Old 04-05-2015, 03:03 PM   #8
burnitg
Looks like a fun build.
Not only are the Detroits much heavier than a small block, they are much taller. I am in the middle of my build ('72 GMC K2500 + 4-53T) and have already had to add a 2" body lift. It looks like I will need at least a 2" suspension lift as well...
burnitg is offline   Reply With Quote
Old 04-07-2015, 12:11 AM   #9
lower50's
lower50's's Avatar
I looked into using a 4-53 in my build, they are about 1200lbs. But sound so cool
1951 MG TD
