Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 11-18-2014, 11:19 PM   #1
65chevysub
65chevysub's Avatar
TH350 TH400 Swap
How hard would it be to swap out my bad TH350 for a TH400?, and what year would I use that hopefully isn't computerized? My truck is a 1965 Suburban, with a 283, '72 Tilt Column for the TH350. I don't want to use a 700R4 or 4L60E if I don't have to as I just use my truck to drive around town, and am on an extremely tight budget.
65chevysub is offline   Reply With Quote
Old 11-19-2014, 01:21 AM   #2
Captainfab
60-66 Nut
Re: TH350 TH400 Swap
Most any year TH400 will work. There are no electronic versions. I would suggest the short shaft TH400, but you will still have to move the crossmember and have your driveshaft shortened. The TH400's came with either a slip yoke, or a fixed yoke. If you get one with the fixed yoke, you will need either a special slip yoke, or have a slip yoke added to your driveshaft. This is assuming you have a one piece driveshaft.
Old 11-19-2014, 08:58 AM   #3
65chevysub
65chevysub's Avatar
Thanks Captain. I still have my 2 piece driveshaft. I believe my mount has been moved when I had the TH350 put in after the Powerglide was removed, and the driveshaft modified a little. Should I stay with the 2 piece driveshaft? I tried a 1 piece several years ago without success. Haven't had any issues with it except the carrier bearing mount broke at the spot welds. I drilled out the welds, and bolted it together and it's still holding. That was about 10 years ago.
Old 11-20-2014, 01:33 AM   #4
Captainfab
60-66 Nut
It sounds like you have the whimpy light duty carrier bearing. I would go with a single driveshaft in a Suburban. That's what I have in mine. If you had a long bed pickup or the longer 1 ton panel, then a 2 piece driveshaft with the HD carrier bearing would be better.
Old 11-20-2014, 08:52 AM   #5
65chevysub
65chevysub's Avatar
It's the original driveshaft it came with. The one thing I, and other members can't figure out, is why some of the Subs came with 1 piece and some with 2 piece driveshafts. My shaft is ok. I just had a problem with the welds on the bearing. I found a driveshaft shop in the Phoenix area, and will check with them about a 1 piece in the future when I get the new trans. Thanks for your help.
Old 12-01-2014, 11:58 AM   #6
65chevysub
65chevysub's Avatar
Just a question about the swap. Should I just stay with a TH350, just a little newer one? The pan on the one I have now says it's a 1978 model, but the pan that could have been replaced.
