Old 11-19-2014, 03:08 AM   #1
CaliforniaDaddy
CaliforniaDaddy's Avatar
What headers are you S10 swapped guys using?
I would like to know what Headers are you guys using on your 350SBC swapped engines. here are a few I found on The Bay.
http://www.ebay.com/itm/301252473208...%3AMEBIDX%3AIT
http://www.ebay.com/itm/330844813420...%3AMEBIDX%3AIT
http://www.ebay.com/itm/150910783321...%3AMEBIDX%3AIT
“I would rather live my life as if there is a GOD and die to find out there isn't, than live my life as if there isn't and die to find out there is.”
CaliforniaDaddy is offline   Reply With Quote
Old 11-19-2014, 10:55 AM   #2
herman quail
Re: What headers are you S10 swapped guys using?
I am putting a t-5 behind my 350 block. I used the headers that fit a camaro with a t-5 option. The one for an auto camero did not fit the clutch slave.
I was told not to use tight tuck headers because they did not breath as well.
Steve
herman quail is offline   Reply With Quote
Old 11-19-2014, 12:10 PM   #3
HUSSEY
HUSSEY's Avatar
That's what I bought. I've seen other guys using them to.
http://67-72chevytrucks.com/vboard/s...=382481&page=3
http://67-72chevytrucks.com/vboard/s...eaders&page=20
http://www.killbillet.com/showthread...y-step)/page24
HUSSEY is offline   Reply With Quote
Old 11-19-2014, 12:28 PM   #4
CaliforniaDaddy
Thanks Hussey, I think I am leaning towards the ball and socket style. Seems like it would seal better.
Old 11-20-2014, 11:25 PM   #5
Atommik
Atommik's Avatar
I used the Patriot s10 v8 swap headers on my 51 with a 327. They fit very well , cleared everything nicely and didn't leak. I ran the steering shaft with a u-joint right thru the headers. It worked out great. See my build, posts 472 and 492 for a couple of pics of the headers installed.
Atommik is offline   Reply With Quote
Old 11-21-2014, 12:45 AM   #6
CaliforniaDaddy
Nice looks good. I think UPS dropped off a package with my new headers in them. I can't wait to get home and see.
Old 11-21-2014, 06:54 AM   #7
Old Crow
Old Crow's Avatar
You Chevy guys don't know how lucky you are.
I've got a '61 F**d F100 shop truck. Some time back, I scored a 302/C6 drive train for it. I, too started looking for headers. Checked out all the usuals(Summit, Jegs, LMC, etc.). No one had an application for headers for a '61 F100 with a small block F**d motor.
In every one of those catalogs, there was a listing for my truck...if I had chosen to put a Chevy motor in it. WTF???
So, then, being a user of forums since they were called usenet, I got on the F**d truck forum and asked the very question the OP asked in this thread. My replies were varied, but they all added up to "get a couple of sets to try and see which one fits".
Really? Like I couldn't have come up with that on my own...if I had a lot of cash, I guess.
So, Chevy guys, count yourselves lucky that not only do you have a truck that the aftermarket manufacturers build parts for, you've got a forum full of actual helpful people like this one.
For the curious, I ended up with stock exhaust manifolds into glass packs, exiting the sides in front of the back wheels. Not what I wanted, but it gets down the road.
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 11-21-2014, 01:18 PM   #8
CaliforniaDaddy
My headers are in. I have the headman part# 69520 I'm going to match this up to a Magnaflow dual in dual out muffler. It almost looks like these made the flanges "gasket-less" Like the Sanderson headers.
Old 11-22-2014, 07:23 PM   #9
Code504.com
Code504.com's Avatar
The Hedman headers as CaliforniaDaddy posted work well, just make sure you use quality gaskets as we've found the flanges to be thinner than desired.
Code504.com is offline   Reply With Quote
