wheel fitment and suspension information needed
Some constructive information needed:
After some reading and numbers crunching.......I find that my cab and chassis rear differential that I thought was going to save me alot of body carnage getting semis to fit, now has to be changed out. Being that I am not linking or bagging my truck right away, the wheels will hit the leaf springs, even going with the direct bolt ons is now not in the cards as has the same issue. So...the way I have things figured, is that I need to take a normal 14 bolt differential (have a couple already) and use that as it will move my tires outward from the C and C differential location 2" per side, but bring them inboard 2.25" from where a stock dually is situated. make sense? Or am I missing something. ....and on another note, what is peoples constructive critisism on the airbar setups for the one ton duallys? What is the best setup out there, or to a well built system that functions well for a daily driver/hauler.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
Re: wheel fitment and suspension information needed
If you just want to lower it http://www.ridetech.com/store/airbar/ if you want to lay frame http://pbfab.com/73-87-rear-dropmember-airbag As far as the semi wheels i have no idea on them.
....cheaper to go with PB.
