Old 11-19-2014, 06:03 PM   #1
Wilson!
GMC cluster indicator color filters
all of the color filters for the lights in my dash are gone. anyone making reproductions? i need them all. green for turn, blue for high-beams, and two red for batt, and oil pressure.
Wilson! is offline   Reply With Quote
Old 11-19-2014, 06:14 PM   #2
Hardrockz28
Re: GMC cluster indicator color filters
I just had to do this myself and what I used was color see-through plastic.
For the red I used Pam cooking oil cap
For green I found a kids pencil box.
It worked out well
Hardrockz28 is offline   Reply With Quote
Old 11-19-2014, 06:50 PM   #3
sixysixss
I've been looking as well. They sell small plastic lenses on ebay for the 55-57 chevy's that you can probably adapt to our GMC trucks, that's what I was looking at. It would be nice to have the lettering on them though. Is the high beam lens blue or green? I thought mine was green.
Rob
1966 GMC 1500
sixysixss is offline   Reply With Quote
Old 11-19-2014, 08:26 PM   #4
Wilson!
i honestly don't know. it was gone when i got the truck and i've never looked at another gmc to see.
Old 11-19-2014, 09:28 PM   #5
jtrichard
high should be RED
jtrichard is offline   Reply With Quote
Old 11-25-2014, 04:01 AM   #6
OldGMJon
OldGMJon's Avatar
There is a guy here on the site that rebuilds gauge cluster assemblies that could probably help...forgot his handle but you could do a search...I saw him listed under the vendors section as well.
OldGMJon is offline   Reply With Quote
Old 12-03-2014, 09:55 PM   #7
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
I made mine from a clear screw container and colored them with Sharpie marker. They turned out pretty good.. Not sure if you can see them in this picture..
MOTOIMPAIRED is offline   Reply With Quote
Old 12-04-2014, 08:59 AM   #8
65chevysub
65chevysub's Avatar
There is a post on here somewhere saying the member used colored plastic sheeting for model kits is what he used. Get it at hobby stores. It's been awhile since I've seen the post, so can't remember the exact details
65chevysub is offline   Reply With Quote
Old 12-04-2014, 02:04 PM   #9
Mike Wessinger
Mike Wessinger's Avatar
I have read about using "lighting gel" for these. I have not tried yet myself, but have that suggestion filed away for when I get to that point.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab
Mike Wessinger is offline   Reply With Quote
Old 12-04-2014, 02:28 PM   #10
sixysixss
Unfortunately, the thing that will be missing with most alternatives is the curvature of the lens and the writing. Has anyone seen a solution that takes both of those into account?
Rob
1966 GMC 1500
Old 12-04-2014, 04:49 PM   #11
kieth
kieth's Avatar
The original lenses in my 66 dash were flat. I ended up making the top 2 green for turn signals, the bottom 2 are red (have not hooked them up for anything but thought about blue for the hi beam and red for a warning light. I used small sheets of plastic and cut the circle out. Kieth
http://kieth.smugmug.com/Trucks/66-GMC/i-X8WmmMg
here is how my 66 dash turned out.......still has the red lenses on the bottom.
kieth is offline   Reply With Quote
Old 12-04-2014, 05:49 PM   #12
sixysixss
That is interesting that your original lenses were flat. My originals are still in my 66 and they are all curved.
Rob
1966 GMC 1500
Old 12-06-2014, 06:19 PM   #13
ljackson
ljackson's Avatar
I used plastic dividers on mine. Turned out good.
http://www.wayfair.com/Avery-Consume...on-X47308.html
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 12-06-2014, 07:12 PM   #14
LVPhotos
LVPhotos's Avatar
I might have some stashed if original is what your looking for.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-06-2014, 08:29 PM   #15
Mjminino
For the red at least, you could use the red tail light tape that is used for broken tail lights. Get some at autozone. It's fairly thick.
Mjminino is offline   Reply With Quote
Old 12-06-2014, 10:59 PM   #16
Leverhead
Plastic binder dividers for me too....semi transparent ones from office depot....you can get a muti pack with different colors. Reverse printed (over clear adhesive film) the text and stuck them onto the divider material. Still looks good.
Leverhead is offline   Reply With Quote
Old 12-07-2014, 02:37 PM   #17
Wilson!
the printing isn't something i had thought of.
i had thought about using a translucent plastic and a colored LED. the lens would be white, until the LED illuminated. i wonder if i can print on one the way you did and it show through the translucent plastic.
Old 12-07-2014, 03:04 PM   #18
Andice
Andice's Avatar
I think they become curved as they deteriorate. Mine were flat on the '64 and mostly missing on the '66 parts truck. What was left of one lens on the parts truck was curvy and very brittle. I had thought of using a Brother label maker along with clear/black labeling tape for the lenses. This particular label maker will print mirror images so the label can be placed on the inside of the lens.
Andice is offline   Reply With Quote
Old 12-07-2014, 04:49 PM   #19
Wilson!
Interesting... A translucent lens with the image on the inside and a colored led to makes the lens glow what ever color you want.
Old 12-07-2014, 08:01 PM   #20
Leverhead
Colored LED is the way I would do it next time...with reverse printed text....or straight printed if you could get it thru the printer!
Pic of mine attached...cant see the text with the camera but it is there...no light in it yet though.....need to find a way to light it up if the elec fuel pump fails .
Old 12-07-2014, 08:45 PM   #21
theastronaut
theastronaut's Avatar
I posted a "how to" on restoring gauge clusters, it has info on making lenses.
http://67-72chevytrucks.com/vboard/s....php?p=5806390
theastronaut is offline   Reply With Quote
