Old 11-19-2014, 11:09 PM   #1
MR COUNTS
Snow plow with lifted truck
Hello can anyone help i have a 1981 chevy k10 with only a 2'' lift and 33x12.50 tires i want to plow with my truck will the 2'' suspension lift make it difficult to do . I was given a meyers 71/2 plow ez mount.the frame is in front of bumper if that matters.
MR COUNTS is offline   Reply With Quote
Old 11-20-2014, 02:59 AM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Snow plow with lifted truck
2" of lift will not be a problem at all. One of my buddies has a plow on a truck with 4" and 35's and does fine.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 11-20-2014, 06:14 AM   #3
donut
donut's Avatar
Should be fine with the lift, though the 7-1/2 foot and 12-1/2" wide tires may be less than ideal. You may be running over your own furrows pushing snow. Just something to think about.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 11-21-2014, 07:53 AM   #4
walkerb
walkerb's Avatar
I don't think you'll have any issue. Just adjust the chain to make sure you have enough free play when its on the ground.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 11-21-2014, 12:49 PM   #5
MR COUNTS
Thank you all for the replys i will be puting the plow on this week end i will put up pictures when its done thanks again.
Old 11-22-2014, 01:39 AM   #6
esbstuff
You will have to be careful about hitting items with th plow down. Too much force will bend the truck frame, if you are using stock plow brackets. The plow angle will put forces up, not back as it was designed to do... If you are careful and plow slow, it will be fine.
esbstuff is offline   Reply With Quote
Old 11-22-2014, 06:13 PM   #7
Kinze
I ran several K20's with 4in. lift and 33's, it actually helps the cutting edge get a better bite with the mount a little higher.
Kinze is offline   Reply With Quote
Old 11-23-2014, 10:48 AM   #8
donut
donut's Avatar
It would for scraping, or popping big rocks out of a gravel drive My Fisher had 3 mounting points on the A frame for angle adjustment. I did have to play with the adjustment and speed of plowing to keep the blade on the ground. Their trip edge design and if angle was too great, would pop the plow blade into the air hitting these rocks. Same rocks would also snap the shear pins on my snowblower, soo... Digging them up wasn't viable as they were 8" plus in diameter (one was over 3') it was much easier on my back to adjust the blade.
Old 11-23-2014, 10:54 AM   #9
Kinze
I would suggest raising the plow 1-2in. off the ground and just skimming it...
Old 11-23-2014, 02:39 PM   #10
donut
donut's Avatar
Better than that, I moved south!
Actually this was in the middle of the driveway, skimming would have left me with ice in the ruts, ice that may still be there in April. (oh, btw, it was in Maine.)
