Help with wiring??????
Hello all,
Got pulled over for not having any brake lights. I tested the little switch under the pedal and the bulbs, they are fine. The hazards are not working on the back end either. Everything up front works fine. It is just the brakes and hazards on the back. The hazard relay is new so it is not that. Does anyone have any advice? Maybe a wiring diagram? Thanks
'72 C-10 '99 Silverado '91 S-Dime |
Inline 69
rear wiring
hope it helps,,,i have dash panel,and engine compartment if u need them also,,,,jeff
Inline 69
do your dash lights work??????/
its all about the +6 inches
Your blinkers are working up front?
If there is no blinkers, i say look for a fuse, and if the fuse is good, you may be looking at a turn signal switch. If they do blink up front, and the parking lights in back still work, then it will be a wireing problem, and probably not a ground issue. Try looking a the Dark green wire, and the yellow wire on the harness. I would start under the rear bumper. It has probably been spliced a 1/2 billion times for trailer harnesses. |
Glowing since 1978
You can take a look at the firewall connector. Should have DG,LG,BRN, and Y wires coming out of it. I think this connector easily came off on the inside of the truck when I was doing my A/C install. The inside connector is just above the gas pedal to the right.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
