Old 11-20-2014, 03:15 PM   #1
thankins93
1987 k20 suburban
i got myself into a lil trouble. i decided hey since i got the motor fixed lets whip it in the yard, and well the c-clip broke and shot the axle out of my axle housing. what i was wondering was if i could swap in a 14bolt FF into the suburban with not problem or am i goin to have to just fix the 14 bolt SF that i got?
1967 chevy stepside, 292 I6, 4 on the floor, 4.11 rear-end
http://www.youtube.com/user/thankins93?feature=mhum
MY 67!
http://67-72chevytrucks.com/vboard/s...d.php?t=446964
thankins93 is offline   Reply With Quote
Old 11-21-2014, 02:14 AM   #2
jetmech85
Re: 1987 k20 suburban
I've have never done that myself but I have a 3/4 ton crew with a 14 bolt FF and I don't see any problem with putting that in a 3/4 ton Suburban.
jetmech85 is offline   Reply With Quote
Old 11-21-2014, 02:15 PM   #3
mattybilt79
A 14b full float is a straight up swap should not require any modifications. Just make sure you get one with the same axle ratio and try to find a later one with the ribbed housing.
mattybilt79 is offline   Reply With Quote
Old 11-21-2014, 06:09 PM   #4
jetmech85
My '85 3/4 crew made in Oct.84 does not have the ribbed housing. My '87 1 ton cab chassis does. That may help in your search.
Old 11-22-2014, 04:44 AM   #5
thankins93
What are the benefits of the ribbed housing? Cooling?
MY 67!
Old 11-23-2014, 03:01 PM   #6
mattybilt79
Stronger housing in general, especially if you decide to go crazy some day and shave the bottom off.
