Old 11-20-2014, 03:57 PM   #1
68wannabe
Spindles?
Just wondering if '71 and '72 disc brake spindles will work on a 1968 c10
68wannabe is offline   Reply With Quote
Old 11-20-2014, 04:05 PM   #2
casper71
Re: Spindles?
You will need to switch the ball joints to larger size.
1972 3/4 ton 402/400
1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift
casper71 is offline   Reply With Quote
Old 11-20-2014, 04:07 PM   #3
68wannabe
Re: Spindles?
Alright, awesome. I was planning on replacing those anyways.
Old 11-20-2014, 04:28 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Re: Spindles?
You will also need the correct outer tie rod ends and adapter sleeves to use them with your 68 inners.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-20-2014, 05:06 PM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Spindles?
I think i found a company that makes spindles for 1963-- 1970 that take the 3/4 ton ball joint and uses all of the stock Tie rod ends and Pittman arm and all the linkage for 258.12
Please call them on shipping.
These are stock spindles Not lowing spindles But they do make lowering spindles
All of you new guys that have 3/4 ton trucks your worries are over Now a 5 lug wheels are in sight.
Now all you have to do is find a 1/2 ton Rear end change the rear springs and the front springs and you will have a 1/2 ton truck better gas mileage and you can put them Alum 5 lug rims on your ride.
The guys using the rear coil Springs you will need to find a Coil spring 1/2 rear end But this is for the guys that have the Leaf spring Rear ends
Part Number CP4S12
This is At CCP they Make front end parts for all trucks
Comes with a Life time Warranty
There in Calif
phone number 1-888-522-8303
I talk to a guy named Mario
They make them for the 2.5 drop spindles as well
All of the Disc bakes from the 1971-72 will work on these spindles
Now i know there will be a ton of you guys that will be
transferring your 3/4 trucks to 1/2 ton with out having to swap front ends
I remembered my Baha friend using some ones spindle that took the 3/4 ton ball joint
and using it on a 1/2 ton spindle
So all you guys swapping out your front ends that have no
Alignment problems your worries are Over Give them a call they do ship as well
stsalvage is offline   Reply With Quote
Old 11-20-2014, 05:08 PM   #6
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Spindles?
Mario told me you can use all of the stock 3/4 ton suspition peaces that came on the 3/4 ton no more trying to hunt down parts for different year's Just change spindles
Old 11-20-2014, 05:11 PM   #7
stsalvage
Scrapper 1
stsalvage's Avatar
Re: Spindles?
If this is all there is there will be a lot of pissed off people that had a front end that was dead on with No shims in there front in for the caster they will Be a person that will just be very up set
Old 11-20-2014, 05:14 PM   #8
Jahloha
Jahloha's Avatar
Re: Spindles?
The simplest write up on drum to disc conversion:
http://67-72chevytrucks.com/vboard/s...68&postcount=4
I decided to go with a kit for my front swap.
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
