Old 11-20-2014, 09:10 PM   #1
trifiveshawn
advise on tire size and lowering kit
I just bought an 85 short bed. Its suppose to have 2 inch spindles in front and shackles in rear. I want to go lower.. I am painting the wheels tomorrow and need to get tires, 15x8 truck ralleys. What size tire can I run with no clearance issues and what lowering kit??
trifiveshawn is offline   Reply With Quote
Old 11-20-2014, 09:19 PM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: advise on tire size and lowering kit
245 60 up front and 275 60 in the rear looks good. If youre in to the big and little look
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 11-20-2014, 09:22 PM   #3
Jake Wade
Jake Wade's Avatar
I have a 2.5/4 drop on my '85 SWB, running 275/60-15 on the rear and 235/70-15 on the front. 15x7 with 4" backspace on front and 15x8 4" backspace on rear, no rub
Jake Wade is offline   Reply With Quote
Old 11-20-2014, 09:24 PM   #4
trifiveshawn
I think id like to use same size tire all the way around using 15x8 and go kinda low
Old 11-20-2014, 10:33 PM   #5
badchevy
Here is a pic of my truck lowered 4/6. I'm running 255/70/15s on 8" rallies all the way around. It has 3" Belltech drop spindles up front and half a coil cut. The rear has a McGaughy's flip kit with the bump stop bracket removed. Hope this helps.
badchevy is offline   Reply With Quote
Old 11-20-2014, 11:01 PM   #6
trifiveshawn
did you do a C notch? any issues on clearance issues?? Looks great btw
Old 11-20-2014, 11:18 PM   #7
thepenguin99
Does the front ever rub? They look great but look like they might rub on the front under the right conditions.
thepenguin99 is offline   Reply With Quote
Old 11-21-2014, 11:53 AM   #8
badchevy
No notch on the back. As for the front, yes, it does rub on hard dips. If I install shorter tires, I wouldn't have this problem.
Old 11-21-2014, 12:11 PM   #9
badchevy
Here are some pics of the rear and front bump stops. The front bump stops were all torn and rotted so I replaced them with the ones in the pic. This also prevents the tire from rubbing on mild to mid dips. The ride is not bumpy or bad at all in case anyone is wondering.
Old 11-21-2014, 08:03 PM   #10
trifiveshawn
Ok im thinking 235 75 15 tires all the way around, a rear 5"flip, thinking ill cut on front springs since it has 2' drop spindles but how much? Also what do I do as far as shocks go? Trying to do budget build.. kinda I ordered front end rebuild kit etc this morning
Old 11-21-2014, 08:49 PM   #11
badchevy
I'm still using the stock shocks up front and ordered lowered shocks for the rear.
Old 11-21-2014, 09:08 PM   #12
trifiveshawn
Cool ty
