Old 11-20-2014, 09:52 PM   #1
Omaha68C10
Auburn posi
I have a buddy of mine who has a 12 bolt truck rear with a 4.88 auburn posi unit. The grear ratio is too steep for my use. Does anyone know if the posi unit will swap into my 68 c10? My truck is a 307 with a SM465 4 speed from the factory which has a 3:73 gear ratio. Thanks,Jon
Omaha68C10 is offline   Reply With Quote
Old 11-20-2014, 11:47 PM   #2
Willys47
Willys47's Avatar
Re: Auburn posi
I belive it will fit but check the Auburn web site to confirm the carrier change over ratio
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 11-21-2014, 07:54 PM   #3
Mike C
Mike C's Avatar
Re: Auburn posi
It should. The carrier break for truck 12 bolts is 3.73 and up. On cars it's 3.90 and up. I have a set of aftermarket thick gears on my truck 3 series carrier that I ran in my Jimmy. That would be the one concern that they are aftermarket gears or something, but most likely not a problem.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-22-2014, 08:40 AM   #4
Re: Auburn posi
x2 ^^
the break off is 3.73-down. Auburns are awesome units. my project has a factory posi and one of the refinements once running will be changing to Auburn for a stronger set-up. My rear was a 3.08 and I changed it to 3.42 for more 4spd (car) grunt while remaining hiway friendly w/o overdrive, and still do well with if I get to that
Old 11-22-2014, 08:23 PM   #5
Mike C
Mike C's Avatar
Re: Auburn posi
The only real drawback to the Auburn unit is the cone type units are non-rebuildable.
Here is West Coast Differentials Carrier Break Chart. This is a good source for just about any rear diff. If you ever look at a 3.73 truck gear set, the ring gear is really thin because of the pinion gear diameter and the fact that the 4 series carrier is 3.73 and up.
http://www.differentials.com/technic...carrier-breaks
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-22-2014, 08:47 PM   #6
Re: Auburn posi
Gear ratios can confuse people. Mike and I are saying the same thing, but he's saying "up", meaning higher number and I'm saying "down", meaning lower gearing. The higher the numbers the lower the gearing. Just wanted to clear that up. I always ask,"Do you mean higher gears or higher numbers?", to be sure when getting info. I'm starting to use tall & short to be more clear...but not consistently
Old 11-23-2014, 01:32 PM   #7
Mike C
Mike C's Avatar
Re: Auburn posi
Agreed. Most people don't have a clue what tall and short mean so it adds an additional degree of confusion!
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 11-23-2014, 10:04 PM   #8
Re: Auburn posi
I don't understand what you mean.
