Old 11-21-2014, 02:48 AM   #1
t72c20
t72c20's Avatar
throttle cable problems
trying to make my factory accelerator cable work with edelbrock carb and intake at wits end.
t72c20 is offline   Reply With Quote
Old 11-21-2014, 02:58 AM   #2
swamp rat
swamp rat's Avatar
Re: throttle cable problems
More info, pictures ect......
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-21-2014, 09:32 AM   #3
asolde
asolde's Avatar
I don't have any pictures yet. But I purchased the edelbrock 8036 adaptor bracket, the 8009 stud for my kickdown cable and the 8016 ball end stud for my throttle cable end. Not sure what kind of set up you have without a picture. If you still have you original throttle cable bracket that will work too but you might have to shorten the cable at the foot pedal to take up some slack again I havent fiqured that out yet either. I have seen one guy take his original kick down stud off the quadrajet and turn it down and rethreaded for the edelbrock I thought that was a good fix. Or just go to the auto parts store and they will have a lot of mixed match stuff for you to use. JEGs has alot of stuff for the attach brackets too.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 11-21-2014, 03:48 PM   #4
swamp rat
swamp rat's Avatar
It may not be a great way to do it but i needed to shorten my cable so i unhooked the end at the floor pedal and pulled the cable out, then i cut the body of the cable and ran a length of hose over it and zip tied it together, at the pedal end i cut the cable a bit shorter and used a cable stop that had a set screw, slid it over and cranked it tight. its been working great for the last 20 years.
I have always wondered if there was a better way as in replacing the cable with an aftermarket.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-22-2014, 04:16 AM   #5
t72c20
t72c20's Avatar
thanks I'll check out edelbrocks cat
