11-21-2014, 06:49 PM | #1 |
Filling rebuilt trans question
Why can't you fill rebuilt trans at first time start up?
11-21-2014, 11:57 PM | #2 |
Re: Filling rebuilt trans question
who says you can't?
11-22-2014, 12:02 AM | #3 |
It won't fill entirely before being started. You'll need to add the remaining fluid while it's idle. Don't wait too long to do this. While it's idling, the fluid in the pan will move to the torque converter (if empty) etc... Keep adding (proper total amount) and checking, adding, checking until it registers full. Then at a standstill, shift through the gears, keeping it in each gear for a couple minutes, then back. Recheck fluid to top it off.
project: "my happy mess" Last edited by litew8; 11-22-2014 at 12:11 AM. |
11-22-2014, 06:21 PM | #4 |
I would strongly advise filling the torque converter before installing it.
11-22-2014, 06:40 PM | #5 | |
If you know the proper capacity of your trans, and you know if you know it's completely empty, then you can keep track of what you add. In my case I could only get 5 qts in. No idea if the rebuilder filled the converter. Once I fired it up, ran it for a bit and got 2 more in. After driving it back and forth and so on I was able to get another 2 in. I think total capacity is 9 for mine.
11-23-2014, 06:14 PM | #6 |
Thanks for your input...I'm going to have my hands full starting up my new crate engine,didn't want to mess with rebuilt th350..builder put in new converter , he put a quart in that , then I put 4 quarts in trans
11-23-2014, 06:27 PM | #7 |
I start with 4 or 5 qts if totally empty then start and fill till its full. You do not want to start the trans empty
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
