Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 11-21-2014, 10:42 PM   #1
Peanutbutter
Need help to identify differential
Hi guys, I don't seen to be able to spend much time here latetly but maybe things will get better. I finally got started work on my 1966 C80 series napco, got it down to bare frame to start sandblasting. I'm more concerned about the front axle, in dire need of new ring and pinion but having trouble identifying. Its a rather large square tube housing with napco tag riveted to the front but it looks like they used 1960s eaton carrier in napco housing. I understand eaton had five differentials starting with the HO52, then HO72, then an 11000 lb, 15000, and last is 17000lb. My ratio is 7.20 with 5 and 36 teeth and I thought it might be the 17 but when I checked the only single speed I had discovered it was to big. Now I'm thinking it must be the 1100 or 15000. My big single I checked tonight is oblong and bolts up with 13 bolts, the one I need is completely round and bolts to housing with 10 bolts. Need info to tell difference between the 11, 15, and 17000lb. Will post some pics tomorrow night, maybe they will help. thanks, Wes
Peanutbutter is offline   Reply With Quote
Old 11-22-2014, 10:56 AM   #2
mrolds88
Re: Need help to identify differential
Did Napco exclusively use Eaton/GM? Since they weren't "brand loyal" as far as customers, maybe they had several suppliers. What about Spicer?
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 11-22-2014, 12:35 PM   #3
Peanutbutter
I don't think I can answer that, all I can tell you is this carrier looks identical to the HO52 and 72s in my 64,65 3/4 ton pickups except its half again bigger, it has a load bolt just like the 3/4 ton carrier. I'll send pics tonight, you can only tell the difference if you had mine side by side with HO72. If you look at picks of the carrier to housing and tin cover plate gaskets you can't tell the difference unless they are next to each other. My carrier measures 14 inchs across, the HO72 probably measures around 12 inchs. They both use 10 bolts on cover and carrier, mine looks like it should be in a 1 1/2 ton. More tonight.
Old 11-23-2014, 12:38 AM   #4
j.kirn
ask over at the napco website
j.kirn is offline   Reply With Quote
Old 11-26-2014, 12:01 PM   #5
mrolds88
PB, I have a PM for you.
93 K2500 xcab 6.5TD
Old 11-28-2014, 07:14 PM   #6
mrolds88
Also one other thought. H110. This was the 11000lb big brother of the H052 and H072.
93 K2500 xcab 6.5TD
