Bed to Cab alignment help
I just got to fitting my bed on today and in order to get a decent alignment the the cab Im having to have to shim the back of the bed up 3/4 of an inch...Is this normal? thanks Jim
1971 Chevy C-10, 5.3, 4L60E,4.10 gears UNDER CONSTRUCTION Mid size bed conversion https://picasaweb.google.com/1114721...yC10MidSizeBed The basic buildup https://picasaweb.google.com/1114721...3/1971ChevyC10 |
Re: Bed to Cab alignment help
Which areas are you correcting? To fix the body lines on the side of my truck I'm not able to use the 1/4" rubber cushions on the front bed mounts but have to shim the back ones up 1/2" or so. Kind of similar to what you are describing.
#3 | |
The gap between the bed and cab ,without the 3/4 inch spacer in the far back bottom of the bed it almost touches the cab on the bottom and I have about an inch up top.. Appears that 3/4 is going to remedy it but just seems odd..thanks jim
Worn out can mounts could affect this too.
Dang auto correct. Cab mounts not can mounts.
![]() Join Date: May 2003
When I did mine I learned that the bed came metal to metal on the frame, no rubber pads. Only the wood floor beds had rubber pads. Not saying this is 100%
True but that's what Brothers told me. Did you put all new mount? Do you have the correct mounts for your truck? C10,s are different from C20's & 4x4's ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
![]() Join Date: Oct 2010
What has been changed on the truck? Cab mounts, radiator support mounts all have effect on panel alignment. If everything is new, check torque specs for each mount. Also make sure you have the mounts in the right place and order. The steel bed does not have rubber mounts although lots have been added over the years. You could also have a frame that has been tweaked over it's lifetime. You can use shims if necessary but check all the possibilities first. Good luck!
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
