Task Force with camaro sub headers?
Im looking to see what headers/manifolds other people are running on their task force trucks with a camaro sub frame. I have a 77 camaro subframe grated on my truck and will be running a small block chevy looking for ideas for what will work. I would like to keep the exhaust tucked close because i dont want to see it from the side. Thanks in advance
1958 Chevy Apache Stepside 1955 BBW Fleetside |
Re: Task Force with camaro sub headers?
I have heard that the Patriot Clipsters fit nice. I put a 81 camaro clip in my 59 and was planning on getting these. Can't tell you how they fit though as I'm not at that point in my project yet.
http://www.summitracing.com/int/part...8036/overview/
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
Mine is a big block but, I do have a '79 or '80 Camaro clip and I simply ordered a set for a Camaro with a big block and fit perfectly.
I think bowt1ed is on the right track.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
#5 | |
http://www.summitracing.com/int/parts/pte-h8021-b
Unless you have changed the engine mounts on the subframe, standard aftermarket headers for 2nd Gen Camaro should work just fine.
Thanks guys. I am in the process of rebuilding my motor and want to start looking for a set. I just wanted to make sure they would clear the cab before i spent any money
A320 Pilot/USAF Retired
They worked well on mine!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
