11-23-2014, 09:40 AM | #1 |
Lift
has anybody ever made their own lift kit? i want to lift my blazer somewhere between 2-4 inches but the cheapest i have found is the 4" from Rough country for $600
11-23-2014, 06:12 PM | #2 |
Re: Lift
For $600, that's probably safer than building your own.
11-23-2014, 06:59 PM | #3 |
SKINNY TIRES RULE!
Re: Lift
You could look for a used kit. Call your local 4wd shops and see if they have one for sale. You may also check on sites like pirate4x4.com and ck5.com.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
11-29-2014, 08:35 PM | #4 |
Re: Lift
You could buy new front lift springs and do A shackle flip In the rear. Still Gets you four inch lift in the rear but you use your stock Springs. Unless you Need new springs this would work and save a little money. But there really isn't a cheap safe way to build your own lift. Unless you are a engineer and master welder is just buy a kit.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
