Old 11-23-2014, 07:05 PM   #1
Triple6Goat
Triple6Goat's Avatar
84 c10 Rochester 2 barrel off idle stumble
Hey guys,
Just picked up a clean rust free 84 c10 that originally came with a 6cyl but was swapped over to a crate GM 350. The swap is clean and looks like it was done some time ago. Anyway, it has a 2 barrel Rochester carb on it. I would love to just rip it off an replace it with a 4 barrel but for now I'd rather drive it as is.
The problem I'm having is an off idle stumble, only under load. I hooked up a vacuum gauge and adjusted both mixture screws properly. I also had to reroute the vacuum lines as they were improperly hooked up. I thought I had the problem solved after doing these two things, but no luck. One thing I didn't do was check timing because I don't have a timing light. Also I don't have a tach hooked up.
Any ideas? I have a 5" autometer tach laying around I might temporarily connect and I'll buy a timing light, but I'm thinking I'll need to rebuild the carb. Also my kick down for the th350 trans doesn't do anything.
Help is appreciated. Cheers!
1984 C10 swb
1985 K20 longbed 4spd
1977 K10 longbed -SOLD
1962 Chevrolet C10 swb 6cyl. 3spd. -SOLD
Triple6Goat is offline   Reply With Quote
