Tailgate Mod/Repair
I plan on installing a latch in my tailgate if possible during the process of repairing my tailgate. I may even install an EZ down shock also to make it like the new silverado tailgate.
Re: Tailgate Mod/Repair
What kind of latch are you thinking about?
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
Have you seen Mar-K's inner latch and hidden arms?
GOD BLESS AMERICA! |
update tailgate.
Are you planning to put the handle on the inside or outside of the tailgate? There are handle re-locator kits available for newer trucks that might make placing it on the inside a lot easier if that's the way you go. Keep taking pics. It's really helpful to see the tailgate opened up so we can see how the process goes. I'm planning on doing something similar sometime but I won't have the benefit of having full access to the inner workings. Please keep us posted.
#8 | |
I champion this idea, it is a small convenient item that I miss about my '67. I am interested to see what you come up with.
63 SWB Stepside --Current Project http://67-72chevytrucks.com/vboard/s...d.php?t=836390 66 SWB Fleetside (Stacy) 350ci/Th400 --Gone http://67-72chevytrucks.com/vboard/s...45#post6595745 67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=633867 |
I thought I had a 73-87 tailgate laying around to get the latch from but no luck finding it. I will probably have to chase on down on craigslist or salvage. I am excited to see if the 73-87 latch will fit.
67 Tailgate. Close to the latch I think I will install. 67-87 look to be very similar.
67 Tailgate
#13 |
07-13 chevy latch pasted on a 65 Tailgate.
#14 |
#15 |
If I were going to use the last pic I would get a locking handle.
#16 |
I have seen a lot of repairs here but this might be the first tail gate repair I have seen on this forum I might be wrong that metal is so heavy a lot of guys shy away from doing it and search for a good one...
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#17 |
I think part of the reason I am rebuilding this tailgate is because I have been thinking about some tailgate mods like a built in latch and EZ down mod. I would feel less comfortable cutting up a new tailgate to try these mods.
#18 |
I could add a remote tailgate release like the new F150. That would be cool.
#19 |
Think outside the box (mini trucks). Suicide door latches with remotes. Actuators for up down. Minis have small metal handles and hardware. I used marine latches from Horkey.
http://www.horkeyswoodandparts.com/page17.php ![]()
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#20 |
Found the same marine latch on ebay for only $14 each.
http://www.ebay.com/itm/NEW-MARPAC-M...-/261341383466 A lot cheaper than paying $99 for a set repackaged as truck latches. If you search around for MARPAC marine latches you may do even better.
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
#21 |
I'm along for this one. I too have thought about this mod. Waiting to see what you use. Thanks for posting it.
#22 |
#23 | |
Should get some more progress done on my tailgate soon. It's been to long already. |
#24 |
If the handle doesn't work for ya check out my handle and latches I used. Works great.
http://67-72chevytrucks.com/vboard/s...d.php?t=659201
1964 ![]() |
