11-23-2014, 07:35 PM | #1 |
Robert Olson Transport
What did you get done 11/23/14 edition
I didn't do a whole lot this weekend to the project truck.. I started to finsh up the gas tank mounting brackets for the 74. Got my sons 79 situated in the back yard and finished cutting up the old plow truck . I made a trailer outta the old bed and chassis and loaded scrap.. so I kinda saved half a square from the Toyota plant
How about you all?
11-23-2014, 09:55 PM | #2 |
Re: What did you get done 11/23/14 edition
Stepside is looking nice.
I've been working on a 2wd Jimmy. Had it shipped up from the south last winter and got it running correctly. Decided to put some effort into it this winter. Only rust was the pass rocker that was packed with red dirt. Cut that out and have the new section about half way tacked in. Also put new valve cover gaskets on. I never understand why people think RTV is going to work well as a long term valve cover gasket all by itself. Finally, I swapped in a 73-74 grill. Stuff like that keeps me motivated through the mundane stuff. Next is trans pan gasket. Need to get all of the stuff done underneath prior to lowering. |
11-23-2014, 10:03 PM | #3 |
I put on new valve cover gaskets and a new radiator this weekend. Haven't gotten the truck started up again yet, just trying to get the rats nest of vacuum lines sorted out. Hopefully with a long weekend coming up I'll be able to get some more done and get this truck on the road!
'84 K20 350/465/208 |
11-23-2014, 10:08 PM | #4 |
At the body shop.
Changed oil and filter prior to the races back on the 9th.
Had a oil pressure issue bought another new wix like before oil pressure right back to normal. Baldwin B7 vs Wix 51794
" That didnt make it any newer " " Dont antique the equipment " |
11-23-2014, 10:12 PM | #5 |
Changed the old steering wheel to the 92 blazer steering wheel I had.
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that! I like long walks on the beach, dinner by candle light, and poking dead things with a stick. |
11-23-2014, 10:15 PM | #6 |
Replaced the bumper mounted park light/signal sockets and installed a rear license plate light in my '82 K-10
Dad's: 1973 Chevy C-60 Grain Truck 366 Big Block Dad's: 1982 Chevy Silverado 6.2L Diesel K-10 Dad's: 1987 Chevy Silverado TBI 350 R-10 Dad's: 2007 GMC Sierra Classic 2500HD SLT Mine: 1982 Chevy Silverado 6.2L Diesel K-10 |
11-24-2014, 12:00 AM | #7 |
Replaced the passenger door striker bolt , the door closes pretty good now .
11-24-2014, 12:14 AM | #8 |
I also replaced a glow plug in my 6.2 Diesel
11-24-2014, 04:40 AM | #9 |
new water pump all belts. fixed m heater core now i have some heat. removed airpump and tryed to retime to get rid of the ping. better still not right
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
11-24-2014, 10:46 AM | #10 |
Didn't do much on my truck this weekend, but did do a lot with it. Friday and Saturday were hay hauling days with Lester, and Friday evening I was on the road 5 hours picking up some musical equipment for my church in the truck. Then I discovered my rear main deal has started leaking a lot worse as a result of the big trip...oh well. Guess I know what to fix now!
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
11-24-2014, 01:34 PM | #11 |
last camping trip of the year , time to winterize and store it all...
Desert |
11-24-2014, 01:41 PM | #12 |
Roadside Rebuilder
Today: Push-rod cover gaskets. Valve cover gasket. General engine degreasing.
Despite being a low-mile original truck, my gaskets are petrified. Distributor was also damn near seized in place, though some ATF and Denatured alcohol (along with some heat) popped her right out. Probably have to finagle an oil-pan gasket in there at some point, which I'm not real excited about. |
11-24-2014, 09:58 PM | #13 |
Finally have something to post in this thread. Changed the oil and filter as well as installed my sport bumper.
11-25-2014, 01:42 AM | #14 |
installed the cummins on my ccsb project and got the interior trim painted and got the front breaks and shocks mounted on the frame
11-25-2014, 02:06 AM | #15 | |
11-25-2014, 12:12 PM | #16 |
I degreased & prepped my bed floor spacers then got them painted. After that I scrubbed the front & rear bed floor sections w/simple-green + scotchbrite. Getting everything ready for the new floor....
11-25-2014, 04:40 PM | #17 |
Im finally geting some motivation back to continue work on my truck.
Got most of the fitting done on my new exhust, still have to fit some hangers and pull pipes over rear axle. Pulled out the old fuel lines and started fitting new ones. Found a crack in my frame under the steering box mount. oh well... itīs comming off anyway
Tom.______________________________________ The fleet: 2007 BMW 530xi M (daily driver) 1986 C-10 Stepside (project "my time") 1992 Corvette cab (summer time daily driver) 1969 Cadilac DeVille Cab ("it just need some paint") |
11-25-2014, 07:53 PM | #18 |
Roadside Rebuilder
This is good to hear! I dislike a leaky motor. While I get free oil at work, it's the mess I can't stand. When an engine is greasy and grimy, it makes the simplest of jobs a real drag.
