![]() Join Date: Jun 2014
temp sensor for vortec heads
Would this GM temp sensor work for my 72 c20 with vortec style heads?
http://pages.ebay.com/link/?nav=item...689969&alt=web My options are either get a stock sensor machined down from 1/2 npt to 3/8 npt, or put the sensor in the intake manifold or if this one above works then I could get this. Thoughts??
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
#2 | |
Cluster King
![]() Join Date: Nov 2012
Re: temp sensor for vortec heads
Your options are to find a temp sender for a gauge with 3/8 pipe thread that has the same ohm range as the stock gauge or like you mentioned, have a stock 1/2 one machined down to 3/8 pipe or you could drill and tap the hole in the head from a 3/8 pipe to a 1/2 hole. Using adapters will not work as it will move the sender out of the flow of coolant. You can also, like you mention, place it in the intake but the intake is the coolest part of the cooling system. The senders work best in the cylinder head because that is where the hottest part of the cooling system is located. Hope this helps, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
I am running a temp sensor in the intake manifold with no problems. actually I think it gives a more accurate reading than being mounted the head.
"Negative people always seem to have a problem for every solution" |
#4 | |
The Older Generation
I don't think that one will work, and mine didn't read even close in the intake because of the thermostat opening and closing. I had one turned down. Be sure they don't thread it too far back or it will break off when you try and tighten it down. There was a member on here turning them down but I don't know if he is still around or not.... LockDoc
My truck has the idiot lights, no gauges. So I need the sensor for lights.
I pm'd member brian mac but haven't got any response. He is the one that was machining them down. I guess I'll do the intake location for now and hopefully I can either find someone else to turn one down for me or mr mac will write me back.
#6 | |
Cluster King
Like LocDoc mentioned, the fluctuation of the temp near the t-stat will make it very hard to keep accurate.
#7 | |
![]() Join Date: May 2010
Duralast TU66
http://www.autozone.com/climate-cont...96492&cmpid=cj interesting discussion here: http://www.corvetteforum.com/forums/...tec-heads.html
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
#9 | |
If you have a temp gauge, it will not work. If you have a temp light, it will work. So will the Autozone part number I gave you. |
I included my post in case someone else needs the sensor for the vortec heads with a gauge. Common problem for old truck vortec guys...
#11 | |
The intake crossover is where the coolant comes after it's gotten the absolute hottest and then it goes though the thermostat to the radiator to get cooled. It does not cool down any at all in the 6" or so it moves from the cylinder head to the intake manifold. The gauge system this truck uses is cave man tech, it only has lines on the gauge and no numbers so how accurate is it anyway. I temporarily used some late model heads on my truck and put the gauge sensor on the intake and it made no noticeable difference, but then again what would it matter on that gauge. |
#12 | |
sorry man, I must of missed you asking me whether I had a gauge or lights.... I have lights, no gauges! This switch that I posted from ebay is actually for another later model gm application....I think v6.....but you're saying it should work on my truck with idiot light? I just typed in temperature sensor GM 3/8 and this is one that came up as well as others....
#13 |
I'm not sure you can even turn the ones for lights down, they are made different than the gauge ones.... LockDoc
#14 |
23/32 bit, 1/2 - 14 tap, 10 minutes and use the correct sensor for your gauge or light.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
